Wie hoch darf der Öldruck maximal sein? | Posts 16+
Go to page: Previous  1, 2
RTDI-Tom
Post10-08-2008, 20:50    Subject: Quote
I need to ask again: What causes excessive oil pressure (how much is 'too high'?) and what can happen in such a case?
Translated on 11-07-2026, 6:32.
Post10-08-2008, 21:56    Subject: Quote
Maximum 7 bar (at a minimum oil temperature of 80°C).
If the oil filter is too high, replace the oil filter adapter if necessary. ... This is what the repair manual says.
There's likely a pressure regulating valve located in the oil filter housing. In older engines, this was always built into the oil pump.
Translated on 11-07-2026, 6:33.
RTDI-Tom
Post11-08-2008, 21:51    Subject: Quote
I'll have him check it tomorrow with a calibrated instrument. What happens if the pressure is too high? What could break?
Translated on 11-07-2026, 6:34.
Post11-08-2008, 22:57    Subject: Quote
RTDI-Tom wrote:
What happens if the pressure is too high? What can break?
Eventually, the seals will wear out and either leak or even burst.
"This has happened to me before with an oil filter. Right from the moment I started the engine, the oil pump built up so much pressure that the sealing ring, which seals the filter cartridge against the holder, burst. The problem back then was a stuck control valve in the oil pump due to debris. However, it was a DX engine (an old 1.8-liter gasoline GTI)."
RTDI-Tom
Post13-08-2008, 14:59    Subject: Quote
I just received a call from the workshop: The oil pressure is fine. However, my RAID instrument continues to show increasing values as the engine speed increases. Does anyone else experience this 'RAID nonsense'? Is it usually the sensor or the instrument itself that's causing the problem?
Translated on 11-07-2026, 6:35.
RTDI-Tom
Post14-08-2008, 17:57    Subject: Quote
The company 'raid' wants to send me a new sensor. Does anyone know about this problem? Is it really the sensor that's at fault, and not the instrument itself?
Translated on 11-07-2026, 6:36.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Issues: How Much Can It Cost? Diesel Engine Technology
No new posts Turbo Pressure: What's the Ideal Setting? Diesel Engine Technology
No new posts Gaspedalstellung maximal 84 bzw 87 Prozent On-Board Diagnostics (OBD)
No new posts Timing Belt 1.9L PD: How Long Does It Last? Diesel Engine Technology
