Skoda Fabia Engine Failure: Troubleshooting & Repair
Boro
Post11-11-2008, 10:01    Subject: Skoda Fabia Engine Failure: Troubleshooting & Repair Quote
Here's a topic I'm posting at your request, as it was asked for in the Ibiza forum. The car might be familiar to some from the Skoda community under the name 'pietsprock.'
If not, here's the text for reference.
http://www.skodacommunity.de/index.php?page=Thread&threadID=32723&pageNo=48&s=963bf8b7a6a5f52bb8cbd70521c8305b6be695ab
The following problem occurs:
'Quote'
'This is about a friend's Skoda Fabia 1.9 TDI that has been...'
On July 3rd, 2000, with his Fabia, he reached almost 616,000 kilometers with very few problems.
has achieved.
However, unfortunately, this has been happening repeatedly for some time now.
short, intermittent engine cut-outs during driving; the engine...
(which usually allows it to) restart immediately afterwards.
Connecting to the diagnostic device and a comprehensive inspection.
Unfortunately, they did not provide a solution to the problem. A rule based on the number of kilometers (it's...
It happened again after 30 km, and then it worked fine for another 15,000 km.
(flawlessly) it happens or can be achieved at a certain speed.
doesn't matter.
Otherwise, the Fabia is working perfectly fine.
He still uses very little, with no increase.
Oil consumption, no change in RPM range.
no noticeable increase in noise during driving compared to...
Otherwise, everything is fine; it's just these occasional glitches that are a problem.
would not have been...
Has anyone ever heard of this problem before?
I have even experienced it myself and also found a solution to get rid of it.
can?
There have been suspicions that the ignition switch...
Perhaps something is 'borrowed' and that occasionally disrupts the connection.
We may lose something in translation. But we are grateful for every tip and idea.
It would be a real shame if the production of the Fabia were to end now.
would have happened. ;;;
MKB is either ATD or AXR, and it has 101 horsepower.
'Nordmouse & Barney'
Here are the links to the SEAT forums.
http://www.ibiza-forum.de/index.php?page=Thread&threadID=70742
http://www.seatforum.de/forum/showthread.php?t=43723
Translated on 26-07-2026, 20:01.
Post11-11-2008, 10:07    Subject: Skoda Fabia Engine Failure: Troubleshooting & Repair Quote
"Sporadic problems are always unfavorable. Try connecting two LEDs (with resistors) to terminals 15 and 30 directly at the motor control unit connector. This way, you can at least see if it's due to a lack of power supply."
Translated on 26-07-2026, 20:06.
Post11-11-2008, 12:02    Subject: Skoda Fabia Engine Failure: Troubleshooting & Repair Quote
The engine cannot be an AXR because the vehicle is too old. The AXR was only introduced from mid-2001 onwards. It must be an ATD.
If there are no error codes stored in the system's memory, then often the only remaining possibility is a problem with the power supply.
A common failure point in this system would be the main contactor relay (formerly known as Rel 109).
This test is quick and easy. Remove the relay and disassemble it. If something like what's shown in the attached image appears, then the fault has been found (torn solder joints).
However, ignition locks are also likely to fail with this mileage. Check as suggested by Rainer.
Another possible cause for intermittent faults is the PD cable harness. It should normally generate at least one entry in the error memory.
This engine does not have a knock sensor (as mentioned in the other threads).
 File size:  73.25 KB
 Viewed:  5225 times
Translated on 26-07-2026, 20:07.
Boro
Post16-11-2008, 18:20    Subject: Skoda Fabia Engine Failure: Troubleshooting & Repair Quote
Sure, I've inserted it as requested!
'Since you've all been thinking about it, I wouldn't want to keep the results of the workshop visit from you...'
The Fabia was thoroughly inspected by the workshop, and during the inspection, a part near the ignition switch, the engine speed sensor, and some other thermostat were replaced.
Initially, a fault in the PDU cable harness was suspected, but after inspection, this possibility was ruled out.
Now, the Fabia needs to be tested, with the hope that the error has now been resolved.
So, please keep your fingers crossed...
'Barney & northmouse'
Translated on 26-07-2026, 20:10.
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DK Skoda Fabia 1.4L 16V Gasoline Engine Technology
No new posts Differential Pressure Sensor Skoda Fabia 5J On-Board Diagnostics (OBD)
No new posts Skoda Fabia RS - Tuning Upload
No new posts Tie Rod Replacement Skoda Fabia Transmission, Chassis, Body & Interior
