DieselSchlumpf
20-01-2009, 21:51 Subject: |
I've already had my fun (I've clicked through everything).
but many things are repeated (for example, the engine speed).
That's why I don't know which lambda value would be the correct one in this case.
Put me back on it tomorrow and I'll start logging  .
Sure, no problem. Here's the translation:
"Thank you in advance."
Translated on 02-09-2026, 11:16.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
20-01-2009, 22:54 Subject: |
Please address the following issues comprehensively and thoroughly:
- Measurement block IDs: 3, 4, 20.
- Measurement block values: 32, 91, 103.
Translated on 02-09-2026, 11:17.
Profile PM WWW Garage |
DieselSchlumpf
21-01-2009, 11:14 Subject: |
I will do that.
So, if I click "start" when the value is at 200, meaning from 6th gear onwards, it's full throttle.
Thank you.
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
21-01-2009, 11:31 Subject: |
Please get help and don't do anything reckless on the train...!! A4 Avant 2,5 tdi 110kw; AFB; BJ2000
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
DieselSchlumpf
21-01-2009, 12:00 Subject: |
Have you ever changed the volume on the car radio while driving?
It's the same... My notebook is already set up, so I just have to click once.
Don't worry, I'll do the evaluation in a parking lot, not while driving  .
Translated on 02-09-2026, 11:18.
21-01-2009, 12:22 Subject: |
Very simple.
With a little memory and a general understanding of the technology, you can start the engine in the parking lot, rev it up, and then stop it again while stationary.
You can definitely identify the actual test run  For example, if the speed is very high and very constant, see here:
Translated on 02-09-2026, 11:19.
Profile PM Garage |
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
21-01-2009, 13:45 Subject: |
Oh, Martin,
Are you driving 20,000 km/h or just 14.5 km/h?
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
matthiasTDI96 Profi-Schrauber
21-01-2009, 14:43 Subject: |
It's already correctly marked as V*10... The curve shows ten times the speed on the left-hand scale. So, a bit over 200.
Jan. 1Z5 CFHF  / AHB H4D
Translated on 02-09-2026, 11:20.
21-01-2009, 15:12 Subject: |
210 exactly
I just unexpectedly received a new engine software update, I think I'll log the data again right away.
m; Transparency, Teamwork
Profile PM Garage |
21-01-2009, 22:17 Subject: |
SORRY!
Translated on 02-09-2026, 11:21.
DieselSchlumpf
22-01-2009, 1:43 Subject: |
@ Rainer
The logs:
http://www.3drc.de/LOG-32_91_103.CSV
http://www.3drc.de/LOG_3_4_20.CSV
In the 3-4-20 log, the engine control unit (ECU) was "missing."
When I went back to the "back" screen, it reappeared immediately, and I was able to read the values.
That's why it's cut off quite early.
Okay, here's the translation:
"Goodbye to the 205 winter tires, 242 km/h according to the speedometer. On the way back, driving on the edge of the lane, 245 km/h."
Starting tomorrow, I will log the same data again using the A-B-T software.
I hope you can "recognize" something in that.
I'm almost to the point where I'm going to offer a reward to whoever can make my car "faster" *g*.
Now, off to bed-de  .
Translated on 02-09-2026, 11:22.
