1.9 TDI AFN: Use Pierburg MAF from Mercedes Sprinter?
davidshoes
Karma: +6 / -2   Thank you, like it!
Post24-02-2009, 14:27    Subject: 1.9 TDI AFN: Use Pierburg MAF from Mercedes Sprinter? Quote
"Hi,"
Years ago, I installed a Pierburg mass airflow sensor from a Mercedes-Benz Sprinter into my Audi A4 1.9 TDI, based on a recommendation. At that time, the prices for the original VW mass airflow sensors were exorbitant.
However, the characteristic curve is probably not supposed to be a perfect fit.
I was looking for an original part and found it at Bosch - it costs €60 new.
What do you think? Should we keep it or change it?
Translated on 05-08-2026, 21:39.
Tobi12345
Post24-02-2009, 15:49    Subject: 1.9 TDI AFN: Use Mercedes Mass Air Flow Sensor? Quote
What do you mean? Should I keep it or should I change it?
I can't give you a general answer to that. I can only tell you about my own experiences. I had a Passat 1.9 TDI PD AVF with 130 hp, and it had a Pierburg mass airflow sensor (MAF) from DC or MB. In the lower RPM range, it was so sluggish that I immediately replaced it with an original MAF sensor from Bosch. To put it briefly, it didn't work for me.
It seems like you haven't had any bad experiences with it, and if it's still delivering good performance, there's no need to replace it. However, if you think it might be failing soon, I would recommend sticking with the original Bosch replacement.
Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 05-08-2026, 21:41.
Avatar-Jan6K
Post24-02-2009, 16:10    Subject: 1.9 TDI AFN: Use Pierburg MAF from Mercedes Sprinter? Quote
"There have been Pierburg mass airflow sensors (MAF) available for some time now, specifically designed for VAG vehicles that typically come with Bosch MAFs as standard equipment. The part number is 7.22684.08.0 and it has a General Operating Permit (ABE) for many VAG models. Unlike the DC-Pierburg sensor, this one is also legal."
I've had this thing installed for a few weeks now and I'm very happy with it – it runs again just like it should, across all RPM ranges.
January.
1Z5 CFHF / AHB H4D
Translated on 05-08-2026, 21:44.
davidshoes
Post24-02-2009, 16:27    Subject: 1.9 TDI AFN: Use Pierburg MAF from Mercedes Sprinter? Quote
You're welcome.
"That's my grandpa's car – it doesn't need much power, and I've mostly been driving it on snow lately..."
Compared to my 3.2, it's not that fast anyway.
I will double-check the Pierburg part number and then possibly order the new Pierburg part.
Best regards, David.
Translated on 05-08-2026, 21:45.
Tobi12345
Post24-02-2009, 16:36    Subject: 1.9 TDI AFN: Use Pierburg MAF from Mercedes Sprinter? Quote
I still have a Pierburg 7.22684.08.0 lying around. I only drove it for a maximum of 5 kilometers when I had it before.
As I mentioned before, the tiptronic transmission didn't work very well with my Porsche Design model.
Let me know if you want it.
Translated on 05-08-2026, 21:46.
No new posts Documentary: LD errors on the Sprinter 315CDI, two-stage ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pierburg MAF Sensor: Fixing Low Readings Troubleshooting & Guides
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Luftmengenmesser 1.9TDI AFN --> Pierburg? Diesel Engine Technology
No new posts SW Holder: Replace or Keep? Transmission, Chassis, Body & Interior
No new posts Brake Cleaner: Bosch vs. Pierburg - Which is Best? Diesel Engine Technology
No new posts OBD for Mercedes Sprinter: Diagnostics & Repair On-Board Diagnostics (OBD)
