Audi A3: Low Power? Diagnose & Troubleshooting
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
sohrab_jan
Post10-03-2009, 16:21    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
Hello everyone,
I'm new here and I already have a problem.
My car, a 2001 Audi A3 TDI with 131 horsepower, engine code ASZ, has very little power.
It accelerates very slowly and has a maximum speed of 120 km/h. The mass airflow sensor was replaced a year ago.
I had the error codes read at A.T.U.
Now it says:
Error code: 17964 - CHARGE PRESSURE - INTAKE MANIFOLD PRESSURE TOO LOW.
Error code: 17564 - INTAKE MANIFOLD PRESSURE SENSOR - OPEN/SHORT CIRCUIT TO GROUND.
What does all of this mean now?
I have an appointment with AUDI tomorrow. Should I have a new turbocharger installed right away, or can that kind of thing be repaired? Can anyone give me some advice? It would also be helpful if someone has had a similar problem.
Thank you in advance!
Marco.
Translated on 30-08-2026, 4:10.
Post10-03-2009, 17:30    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
It's all right there.
Boost pressure sensor...
First, it's important to examine (or have someone examine) the device (and its cables) closely.
Or do you always buy new cars when the tank is empty icon_smile.gif?
Greetings.
Martin.
Translated on 30-08-2026, 4:12.
sohrab_jan
Post10-03-2009, 17:48    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
dieselmartin wrote:
It's all right there:
Greetings.
Martin
"It's not as simple as you're making it sound. When reading the error codes, the possible cause listed is:"
- Air leak
- Generator/regulator defective.
- Possibly, boost pressure outside of tolerance.
- Vacuum line defective/leaking/blocked/stuck.
- Faulty boost valve.
- Vacuum sensor defective.
- Faulty boost pressure sensor.
- Turbocharger failure.
-Faulty control unit.
- Cables/Connectors: Open circuit/Short circuit to ground: Voltage/Resistance.
Translated on 30-08-2026, 4:14.
Wiesel
Post10-03-2009, 18:13    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
I have no idea which tool "Auto Killer" uses, but it's something related to error codes.
It's kind of unhelpful to just say "go outside."
INTAKE MANIFOLD PRESSURE SENSOR - OPEN/SHORT TO GROUND
"This is a very clear statement that narrows down the error to three possible locations."
- Turbocharger pressure sensor (not impossible, but rather unlikely).
- Engine control unit (even less likely)
I would like to take a very close look at the connection (including the connector on the sensor).
remove and check for corrosion).
Abrasion marks, badger bites, ...
Once the error is fixed, the other one should disappear as well.
Can I rule out the turbocharger?
He can't be responsible for any interruptions or short circuits.
It doesn't look too bad.
Best regards, Micha.
Translated on 30-08-2026, 4:16.
sohrab_jan
Post10-03-2009, 19:15    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
Wiesel wrote:
I have no idea which tool "Auto Killer" uses, but the one that deals with error numbers.
INTAKE MANIFOLD PRESSURE SENSOR - INTERRUPTION/SHORT TO GROUND
Best regards, Micha
Can you tell me where I can find this sensor? I'm a complete beginner in this area. Will I be able to see the connector right away, and what does it look like?
Translated on 30-08-2026, 4:19.
Post10-03-2009, 21:20    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
The boost pressure sensor (ASz) is located below the passenger-side headlight (on the left side when facing the car) and is mounted on top of the air conditioning condenser. Accessing it can be tricky, especially with xenon headlights, but it's possible with skillful fingers.
Translated on 30-08-2026, 4:20.
sohrab_jan
Post11-03-2009, 14:08    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
"I was at Audi today, and they determined that the turbocharger pressure sensor is broken, and they may also need to replace the metal valve on the turbocharger. Is the turbocharger pressure sensor the same thing as a boost pressure sensor? Can this be replaced by yourself or at an independent workshop? Or would you recommend going to the Audi dealership? The cost at Audi is approximately €450."
Thank you in advance.
Translated on 30-08-2026, 4:21.
Post11-03-2009, 14:14    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
Wenn der tatsächlich defekt sein solltem, was wirklioch eher selten der Fall ist und du einen fehler im KABELSTRANG ausschließen kannst, dann ist auch der Wechsel für Normalbegabte kein Problem. Siabove.
Metal valve on the turbocharger. Oh dear, what kind of Audi workshop is this? Please provide the exact part numbers.
Translated on 30-08-2026, 4:22.
sohrab_jan
Post11-03-2009, 14:19    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
Metal valve on the turbocharger. Oh dear, what kind of Audi workshop is this? Please provide the exact names/designations.
Unfortunately, I don't have any labels icon_rolleyes.gif. I recently had an accident on the right side, and it's possible that it broke. However, that makes me suspicious, because I also didn't have any power before the accident. So, it probably couldn't be the boost pressure sensor if I had this problem before the accident, right?
Translated on 30-08-2026, 4:23.
sohrab_jan
Post12-03-2009, 21:29    Subject: Audi A3: Low Power? Diagnose & Troubleshooting Quote
Okay everyone, first of all, thank you for the responses. The problem has been solved; the boost pressure sensor was faulty.
No new posts Much Show, Little Value: Sports Air Filters Technical Articles
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with AFN: Very little performance when running in... Diesel Engine Technology
No new posts Ibiza 6L ASZ - Sudden lack of power below 2500 rpm, log Upload
No new posts Ibiza 6L: Low Power Below 2500 RPM? On-Board Diagnostics (OBD)
No new posts Fensterheber vorne bei Audi A6 Bj. 98 will kaum noch hoch Transmission, Chassis, Body & Interior
