The heating system in my grandparents' A4/B5 car has stopped working.
Workshop diagnosis: Heat exchanger is blocked and needs to be replaced, cost: €480.
After that, the whole thing would likely have been back to normal in a short time, as algae were already growing in the balancing tank.
I then took on the matter.
Equipment:
Ramp, pit, or lift platform (it was just a small ramp).
3 bottles of G12++ coolant.
1 bottle of cooling system cleaner.
Thermostat.
O-ring.
Tool.
So, I first removed the underbody panel and drained the coolant (Caution: Harmful to health and requires proper disposal!).
It looked more like muddy water. Also, the bottom of the collection basin was covered with rust particles, some of which were as large as a fingernail.
Then I removed the thermostat.
After that, I reassembled everything without the thermostat and filled it with 1.5 liters of cleaner and clear water. --> Turn on the heating - for at least 20 minutes.
Everything was drained out - the liquid turned back into a slurry of pigment and rust particles.
I put the old thermostat back in and started another cleaning cycle.
Okay, I'll translate the text:
"Again, I removed everything and then unscrewed the hoses for the heat exchanger in the engine compartment. I flushed them in both directions with a garden hose (but it barely worked)."
Reassemble everything and fill it with clean water. Additionally, dissolve two dishwasher tablets in the water and run another heating cycle.
Okay, let's drain everything again. Flush the heat exchanger and refill it with dishwasher tablets. This time, also install the old thermostat. Run the system, drain it, and then flush the engine, radiator, and heat exchanger with the hose (in both directions).
Finally, install the new thermostat, reattach the underbody panel, fill the system with G12++ (mixed 1:1 with distilled water), and bleed the system.
Ready - it's heating up again.
Approximate cost: Thermostat €35, G12++ coolant €39, and cleaner €38 (enough for 3 flushes).
Interestingly, the cleaner's instructions state: "Drain the coolant, bring the engine to operating temperature, and add 1.5L of cleaner, then top off the rest with clean water..."
I definitely wouldn't pour cold cleaning fluid into a warm engine, and I wouldn't let the engine run for a long time without water... What do you think?
It was quite a job, but without a thorough cleaning, even replacing the heat exchanger won't make much difference. And the workshop definitely won't clean it with that level of effort!
In March, we'll also be doing a transmission fluid change and replacing the shock absorbers.
