Screw broken off in the turbocharger
onclebenz
Karma: +0 / -2   Thank you, like it!
1987 Mercedes-Benz SL Class
Post23-03-2009, 17:02    Subject: Screw broken off in the turbocharger Quote
GAU: A screw has broken off in my turbocharger.
I'm currently cleaning the VTG because the distribution was clogged, and now...
How can I best get them out?
2. Who can supply this type of screw? M4 x 20 Torx 20 head (strength?)
This is a Garrett turbocharger with Variable Turbine Geometry (VTG) from a VW Lupo 3.0.
die anderen Autos stehen in der "Garage"
LUPO 3l 1,2 TDI MKB: ANY Mod.Jahr 2001 220000km
MERCEDES 200D Bauj.1966 KM ??
VW T4 2.5i Multivan Bauj. 1994 240000 KM
Post23-03-2009, 18:54    Subject: Screw broken off in the turbocharger Quote
Weld the motherboard and then try to remove it.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post23-03-2009, 19:07    Subject: Screw broken off in the turbocharger Quote
I would heat the casing to 150-200 degrees and spray it with rust remover. First, secure the remaining bolt with locknuts, then try to loosen it. Welding is a second option, drilling is the third. Election. icon_eek.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Devilseye503
Post24-03-2009, 19:56    Subject: Screw broken off in the turbocharger Quote
...or pry it open with a screwdriver and manipulate it... it's best to heat it up beforehand.
onclebenz
Post25-03-2009, 13:13    Subject: Screw broken off in the turbocharger Quote
Thank you for the tips!
The screw is now out.
I had something welded twice.
Every time, the screw breaks off.
I was already a bit grumpy.
A kind friend has now removed the stub and then smoothed out a slight indentation.
Then, I drilled out the screw using a 2mm drill bit.
fumbled around, broke off a tap.
but then, eventually, they succeeded.
Great! Saved 450 euros!
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI Timing Belt Tensioner: Broken Bolt. Diesel Engine Technology
No new posts High-pressure pump screw sheared off, need help Diesel Engine Technology
No new posts Missing screw from brake disc assembly (torn off) - is th... Transmission, Chassis, Body & Interior
No new posts Broken Engine Mount: Causes & Repair Diesel Engine Technology
