Chip tuning installed or not, 3BG 2.0
blackpearl136
Post21-04-2009, 19:16    Subject: Chip tuning installed or not, 3BG 2.0 Quote
Hello everyone,
I'd like to know which log data I can use to identify something.
Has chip tuning already been done on my 2.0 TDI with 136 horsepower?
Do tuners leave their trademark anywhere?
Bin vorher Benziner (125PS) gefahren. Therefore,
Thank you in advance for any responses you may provide.
Translated on 11-07-2026, 6:54.
Tobi12345
Post21-04-2009, 19:39    Subject: Chip tuning installed or not, 3BG 2.0 Quote
The easiest way to tell is by looking at the boost pressure and fuel injection volume. If these values deviate significantly from those specified in the data label, it's possible that something has been modified.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 11-07-2026, 6:55.
Post21-04-2009, 19:42    Subject: Chip tuning installed or not, 3BG 2.0 Quote
The label files, like the information provided by VAG itself, have a rather wide range of variations.
-> Log file from measurement block 1 and 11 at full load, with speeds ranging from 2000-4000 rpm. Also include the ambient pressure reading from measurement block 10.
Translated on 11-07-2026, 6:56.
blackpearl136
Post21-04-2009, 20:05    Subject: Chip tuning: yes or no? Quote
Super fast responses.
Sure, no problem.
My friend has a VAG-COM device, and we recently obtained the following log files.
pulled.
Okay, I'm ready. Please provide the German text you want me to translate into English.
It's peculiar that the periods of acceleration occur during times when...
The values listed come from the archives of AutoMotorSport and pertain to a sedan. By the way...
I do not have standard equipment icon_biggrin.gif.
Greetings.
Translated on 11-07-2026, 6:57.
teufel.k
Post28-04-2009, 18:53    Subject: Chip tuning: yes or no? Quote
Hi, in measurement block 26, a coding is displayed. This coding should be sent to Volkswagen via a VW operating system with a DISS message.
You will then be informed whether chip tuning has been installed.
Karl.
Translated on 11-07-2026, 6:58.
Post28-04-2009, 19:24    Subject: Chip tuning installed or not, 3BG 2.0 Quote
devil.k
Translated on 11-07-2026, 6:59.
Benni
Post28-04-2009, 20:25    Subject: Chip tuning installed or not, 3BG 2.0 Quote
Is this an inside joke or do I not need to understand it? *blank stare* icon_redface.gif
Post28-04-2009, 20:33    Subject: Chip tuning installed or not, 3BG 2.0 Quote
Mr. Teufel's proposal would likely permanently mark the vehicle as "tuned" within the VAG system in case of any issues. icon_cool.gif
Translated on 11-07-2026, 7:00.
blackpearl136
Post29-04-2009, 11:14    Subject: Chip tuning: yes or no? Quote
@BenniViewing profile: Benni,
According to your information, do you have the same vehicle type?
Könntest du nicht mal so ein LOG über Beschl. 4. 5. 6. Gcertainly
create? with parameters like fuel injection amount, boost pressure, air mass, etc.?
Then we could compare them.
Post29-04-2009, 12:06    Subject: Re: Chip tuning or not? Quote
blackpearl136 wrote:
@Benni,
Regards
How about you first implement what I wrote?
Otherwise, I can save myself the trouble of providing any further answers. icon_rolleyes.gif
Translated on 11-07-2026, 7:02.
blackpearl136
Post30-04-2009, 22:52    Subject: Chip tuning: yes or no? Quote
Hello everyone,
We were able to record the following data today: one instance of using the 6th gear, but it was then interrupted.
Okay, fifth gear again. I had already set some data before. But it doesn't seem to be working.
"Were you interested?" or "Did you want to know?" (depending on the context)
" /viewtopic.php?p=148283#148283 "
The corresponding data is located there.
Translated on 11-07-2026, 7:03.
Post01-05-2009, 8:48    Subject: Chip tuning installed or not, 3BG 2.0 Quote
I had already set up the data before. But it seems like it's not working.
interessiert zu haben?!
Your car is not tuned.
Translated on 11-07-2026, 7:04.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Chip Tuning: Pros and Cons Upload
No new posts New question about chip tuning or tuning box Diesel Engine Technology
No new posts Is there something wrong? Transmission, Chassis, Body & Interior
No new posts What type of water pump is installed in the 2.0 TDI engine? Diesel Engine Technology
