Hello Andy,
Thank you for your comment. I'm experiencing the same problem with a Passat, and I was already planning to change the coolant and have a pressure test done.
Okay, I'm going to check the function of the pressure switch and its power supply first.
Best regards!
Dirk.
A little feedback:
Replacing the pressure switch is really straightforward and, believe it or not, possible without having to drain the entire system. It's worth remembering to get a new sealing ring beforehand; mine was unusable after removing the old pressure switch.
The used, new pressure switch now exhibits switch-like resistance values.
This, however, was not the solution to the problem.
I then found the solution in the missing power supply to the pressure switch.
A surface-mount transistor in the Climatronic control unit was defective, and this transistor switches a surface-mount FET to provide +12V to the pressure switch. Because the voltage was missing at the pressure switch, the subsequent logic circuit could not detect that the system was operating at the correct pressure --> the compressor was not activated.
I replaced the transistor with a standard BC 547 that I had lying around, and now the FET is being controlled correctly again.
The alternative to this annoying noise is simply a new control unit from the dealer, costing 319 euros plus VAT.
Hella, as the manufacturer of the control unit, is unfortunately unable to supply spare parts for it.
Now it's pleasantly cool again...
Best regards, Andy
