Rear Diff Bushings Golf 4
Jürgen
Post13-06-2009, 22:25    Subject: Rear Diff Bushings Golf 4 Quote
I'm currently working on finishing up a remaining task from the last inspection.
I removed the rear axle from my Golf IV to replace the rubber-to-metal bushings.
After removing the old bearings, I discovered that they were hydrodynamic bearings with an outer diameter of 69mm. The holes in the shaft are approximately 69.5mm.
I went to the dealership and got new bushings. However, they only have rubber-to-metal bushings now, and they have a diameter of just under 72mm, which is a difference of a full 2mm. The knowledgeable staff at the dealership told me that there's only one type of bushing available, and they wouldn't reveal any more information, nor would the catalog. I've since found out that, according to the original documentation, the hydraulic bushings were actually replaced with rubber-to-metal bushings. I'm just bothered by the 2mm difference in diameter. Has anyone else done this before? Could the bushings be pressed in using an M12 threaded rod and corresponding pressure plates (which I have), or do you need a press? I have a hydraulic press, but I don't currently have anyone to help me position the heavy axle vertically on the press.
Translated on 11-10-2026, 6:09.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post14-06-2009, 12:27    Subject: Rear Diff Bushings Golf 4 Quote
Hi Jürgen, I have some with diameters of 72 mm and 69 mm.
If the replacement is made of plastic and 72mm in size, it might fit. But metal definitely won't work.
I just checked Lehmförder again, and they have a bearing size of 71.4 mm (replace hydraulic bearings in pairs).
You need to measure again, more precisely.
1J0 501 541 C = 72 mm
1J0 501 541 D = 69 mm
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 11-10-2026, 6:11.
Jürgen
Post14-06-2009, 18:37    Subject: Rear Diff Bushings Golf 4 Quote
Thank you, Teileklaus.
I've already had 2 batteries with a 72-cell configuration (the outer diameter of the metal casing is 71.5-71.8mm).
icon_smile.gif purchased. I was brave enough to try pressing it in. I thought I'd risk the €20 if it went wrong. But lo and behold, it works quickly with an M12 threaded rod and the necessary pressure pieces - which I had from a wheel bearing tool set that I bought cheaply on eBay. It wasn't even very strenuous. I only lightly lubricated the outer bearing surface and the housing in the rear axle with engine oil. The housings in the rear axle have a slight recess on both sides, which makes the process much easier. However, you can already see that the metal casing pushes a slight bulge ahead of it as it enters the housing. Therefore, you no longer need to use the 1J0 501 541 D bearings - the icon_smile.gif was actually right, you can generally use 1J0 501 541 C.
Translated on 11-10-2026, 6:13.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post14-06-2009, 19:04    Subject: Rear Diff Bushings Golf 4 Quote
Okay, 69 mm would have been too small anyway, if you had a 69.5 mm hole!
Translated on 11-10-2026, 6:14.
Jürgen
Post14-06-2009, 19:44    Subject: Rear Diff Bushings Golf 4 Quote
I don't believe that, because the old bearings were hydrolubrication bearings!
Translated on 11-10-2026, 6:15.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post14-06-2009, 21:09    Subject: Rear Diff Bushings Golf 4 Quote
Jürgen, I see a 0.5 mm gap. Is that a 69-sized bushing in a 69.5-sized hole?
Jürgen
Post16-06-2009, 15:33    Subject: Rear Diff Bushings Golf 4 Quote
Of course, I had already thoroughly cleaned the area around the rear axle, making it completely spotless. There were definitely hydraulic supports in there, which had been empty for a long time and were, accordingly, corroded.
I couldn't imagine that the new 72s would be installed without some brutal force, but the outer casing is so soft that it deforms and adapts perfectly. I wanted to continue working on it tonight, and I'm still dealing with the two simmerings of the differential, and I also had a new MFA display soldered into the instrument cluster. My wife is currently in the hospital, so I can take my time.
Best regards, Jürgen.
Translated on 11-10-2026, 6:16.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post20-06-2009, 21:20    Subject: Rear Diff Bushings Golf 4 Quote
I don't know if this will be helpful, but I also replaced the rear axle bearings on my A3, which was manufactured in 1997.
Specifically, the originals consist of an outer plastic casing, then rubber, and in the middle, an aluminum block that is secured with two rubber strips.
These were replaced with polyurethane bushings from Powerflex.
These were 72 mm in size. The originals were 69 mm.
I never thought it would work, but with the installation tool and an impact driver, it eventually went in. But it was a very tight fit.
If the rubber bushings are on the outside, I'm quite sure they will fit.
Translated on 11-10-2026, 6:17.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post02-07-2009, 22:10    Subject: Rear Diff Bushings Golf 4 Quote
@SoupOfTheDay
Do you feel a significant difference between the PU bearings and the old bearings?[/quote]
reflexsilber met.
Translated on 11-10-2026, 6:18.
Tagessuppe
Post03-07-2009, 15:08    Subject: Rear Diff Bushings Golf 4 Quote
The difference is enormous. In fact, it's even more pronounced on the rear axle than on the front.
The resulting loss of comfort is relatively small.
Only small, hard edges are swallowed less easily than before.
Probably because here, the pulling happens both backwards and upwards simultaneously.
Translated on 11-10-2026, 6:19.
RedR32
Avatar-RedR32
Post03-07-2009, 20:48    Subject: Rear Diff Bushings Golf 4 Quote
Okay, I understand. I will include the original versions.
Bye.
reflexsilber met.
Tagessuppe
Post03-07-2009, 21:40    Subject: Rear Diff Bushings Golf 4 Quote
Why?
The PU bushings offer a much sportier driving experience.
If I had the choice, I would always install polyurethane bushings.
Translated on 11-10-2026, 6:20.
RedR32
Avatar-RedR32
Post04-07-2009, 7:48    Subject: Rear Diff Bushings Golf 4 Quote
Hi.
I installed PU bushings for the torque strut because they were cheaper than the complete strut from icon_smile.gif. I probably didn't check to see if the rubber bushings were available separately. In the TDI engine, this definitely doesn't work! Because they are much too hard. Since then, I've had serious concerns about installing PU bushings. I still have a set of large PU bushings for the rear axle, and I'm still hesitating about putting them in.
Has the sound of the rolling mechanism changed?
reflexsilber met.
Tagessuppe
Post04-07-2009, 11:29    Subject: Rear Diff Bushings Golf 4 Quote
Yes, this rubber for the torque strut is also available individually.
I've made that mistake before, buying a complete support system.
I thought it would shake my car up.
The rolling noise has not gotten louder.
As mentioned before, the level of comfort remained almost the same.
Translated on 11-10-2026, 6:22.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Best way to glue rubber: Tips & tricks. Transmission, Chassis, Body & Interior
No new posts Servo Oil: Harmful to Rubber and Tires? Diesel Engine Technology
No new posts VW Golf 3 Rear Axle Rubber-to-Metal Bushing Transmission, Chassis, Body & Interior
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
