lupo3l Guest
24-04-2003, 21:10 Subject: Specialty Tools: Where to Buy & Find Them |
Hello.
I need the 'crankshaft locking tool T10050' from VW for the timing belt replacement. Where can I get this specialized tool, or a dimensioned sketch to build it myself?
lupo3l
Translated on 19-08-2026, 22:18.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
24-04-2003, 21:45 Subject: Specialty Tools: Where to Buy & Find Them |
So, you can watch it and I think you might also want to buy it; for example, you can find it here:
http://www.hazet.de/deutsch/produktinfo/pdf/2588_3.pdf
I would also be interested in the exact dimensions. Has anyone perhaps already made this tool themselves, or does anyone have a CAD drawing or something like that?
Okay: Does anyone know how much a set costs from Hazet?
See you later.
pretzelman01
Translated on 19-08-2026, 22:19.
Rudi Guest
24-04-2003, 22:18 Subject: Specialty Tools: Where to Buy & Find Them |
Sketches and similar things were posted here in the forum just a few weeks ago.
-> Search function
Best regards, Rudi.
Translated on 19-08-2026, 22:20.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
25-04-2003, 0:19 Subject: Specialty Tools: Where to Buy & Find Them |
www.matra.de
They are the main supplier of specialized tools for VW! Simply inquire and order by email (only if Hazet does not have the tool)  . ____________
Kein Auto mehr!
Translated on 19-08-2026, 22:21.
lupo3l Guest
26-04-2003, 12:38 Subject: Specialty Tools: Where to Buy & Find Them |
Awesome!
Thanks for the tips. I just ordered the Hazet set 2588/3 (crankshaft locking tool = 'T10050', locating pins = 'T10008' and locating pin = '3359') for EUR 69.99 (including VAT). I'll receive the tools in mid-May, then it's time to replace the timing belt on my engine!
Best regards.
lupo3l
soave Guest
27-04-2003, 10:05 Subject: Specialty Tools: Where to Buy & Find Them |
Hello!
So, I borrowed the camshaft alignment tool and the bolt for securing the crankshaft position sensor (AFN) from a VW workshop for two hours, and then had a locksmith make me a copy of it.
They work perfectly fine. They cost me 12 German Marks back then.
Just a thought.
Greetings.
mild; gentle; soft; pleasant
Translated on 19-08-2026, 22:23.
haehnlein Schrauber
27-04-2003, 12:04 Subject: Specialty Tools: Where to Buy & Find Them |
soave wrote: | So, I borrowed the camshaft alignment tool and the bolt for securing the crankshaft position sensor (AFN) from a VW workshop for 2 hours, and then had a locksmith make a copy for me.
These things work perfectly fine. They cost me 12 Deutsche Mark back then. |
It's about a pump-injector  . For the VP37 TDI, you can make it yourself (or have it made)  , and you are right about that. ____________
Kein Auto mehr!
Translated on 19-08-2026, 22:24.
soave Guest
27-04-2003, 23:49 Subject: Specialty Tools: Where to Buy & Find Them |
'... Oh man! I must have messed that up!'
Translated on 19-08-2026, 22:25.
haehnlein Schrauber
28-04-2003, 13:17 Subject: Specialty Tools: Where to Buy & Find Them |
soave wrote: | | ... Oh man! I probably messed that up! |
No problem...it happens to me too sometimes  . ____________
Kein Auto mehr!
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
28-04-2003, 13:53 Subject: Specialty Tools: Where to Buy & Find Them |
Here's a dumb question: What is the purpose of the crankshaft locking mechanism?
Put the car in 5th gear, move it until the drivetrain is under load, one person steps on the brake, and that's it?
The clutch needs to be able to handle the engine's approximately 300 Nm of torque, and shouldn't any screw on the crankshaft be tightened securely?
Translated on 19-08-2026, 22:26.
Profile PM WWW Garage |
haehnlein Schrauber
28-04-2003, 14:23 Subject: Specialty Tools: Where to Buy & Find Them |
Rainer K. wrote: | | Once upon a time, a silly question: what is the purpose of the crankshaft locking mechanism? |
Hi Rainer,
It is possible that the crankshaft could twist when tightening the belt  . At least, this thin part is not sufficient to hold the crankshaft in place if the crankshaft bolt is loosened. You really need to use the VW 3099 for that... but the bolt doesn't actually need to be loosened to change the timing belt, does it?  ____________
Kein Auto mehr!
Translated on 19-08-2026, 22:27.
joergs Guest
28-04-2003, 16:35 Subject: Specialty Tools: Where to Buy & Find Them |
When I changed the timing belt on my 1Z engine, I wished I had a part like this to lock the crankshaft. It's quick and easy, and you can easily be one tooth off! Without it, it quickly becomes a test of patience!
Translated on 19-08-2026, 22:28.
haehnlein Schrauber
28-04-2003, 17:56 Subject: Specialty Tools: Where to Buy & Find Them |
joergs wrote: | | When I changed the timing belt on my 1Z, I wished I had a part like this to lock the crankshaft. It's quick and easy, and you can easily skip a tooth! 8)Without it, it quickly becomes a test of patience! |
Hi Jörg,
I've come up with a little trick for that:
You need to rotate the crankshaft slightly counterclockwise (about 1-2cm measured from the TDC mark) before installing the timing belt. Then, try to install the timing belt, and when you are doing so, make sure to route the belt over the water pump (WRP). While doing this, rotate the crankshaft into the TDC position under tension  . This ensures that the number of teeth between the eccentric pulley (ESPRad) and the crankshaft is correct, which prevents the crankshaft from rotating when tightening the timing belt  . If it does, the valve timing will not be correct afterward  . ____________
Kein Auto mehr!
Translated on 19-08-2026, 22:30.
joergs Guest
28-04-2003, 18:24 Subject: Specialty Tools: Where to Buy & Find Them |
That's exactly what I did after the third failed attempt!
But next time, only use a torque wrench!
Translated on 19-08-2026, 22:31.
