chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
28-07-2009, 7:50 Subject: Sharan Brake Pad Wear Sensor |
"Hi, I'm having a problem with my Sharan. When I turn on the ignition, the brake pad warning light immediately illuminates. Then it goes off again, but sometimes it also comes on while driving. The front and rear brake pads are new."
I've also sprayed contact cleaner on the connectors.
Has anyone else experienced this problem?
Chris
Sharan, year of manufacture 2005, 4Motion. A6 AFB
A6 BRE DPF
Translated on 09-09-2026, 7:26.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
28-07-2009, 19:21 Subject: Sharan Brake Pad Wear Sensor |
There must be a broken cable somewhere. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
Steffen W Profi-Schrauber
Joined: 07/05/2008 Posts: 1276 Karma: +104 / -0 Location: Altenburg
29-07-2009, 6:18 Subject: Sharan Brake Pad Wear Sensor |
I've experienced this before with a Passat. I had new brake pads installed, but the warning light still came on. Often, it only appears after turning the steering wheel.
"In my case, it was due to the wiring harness that runs from the brake pad connector to the fender. You could buy that part from Febi. The ABS sensor is also connected to it in the Passat." Passat Variant BGW 2005
Translated on 09-09-2026, 7:27.
chriskross Blaumann
30-07-2009, 11:16 Subject: Sharan Brake Pad Wear Sensor |
I've temporarily disabled the ad.
Is this plug also available directly from VW? A6 AFB
A6 BRE DPF
30-07-2009, 20:03 Subject: Sharan Brake Pad Wear Sensor |
The connector housing that's attached to the wiring harness is available separately. You can also find cable sections with connectors that are compatible for connecting. It doesn't cost much.
I'm not sure about the connector that's attached to the brake pad. Passat Variant BGW 2005
Translated on 09-09-2026, 7:28.
