Torque Wrench 27Nm: Troubleshooting Noise Issues
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post05-09-2009, 20:15    Subject: Torque Wrench 27Nm: Troubleshooting Noise Issues Quote
Hello, regarding the replacement (pressed with appropriate tools and clamps) of the two rear left drive shafts on the Alhambra 1.9 / 115 hp, manufactured in 2001, with 133,000 km, I used an impact wrench to tighten the drive shaft screw, and then loosened it again. I then tightened it to approximately 250 Nm. That was probably not the intended procedure. icon_rolleyes.gif
What should the preload torque be before I turn it 1/4 of a revolution further?
The distinct wheel bearing noise is gone, but there's a faint, quiet, rapid, and pulsating sound that's related to wheel speed, and it's only audible when turning the steering wheel slightly to the left, and it doesn't occur constantly while driving. I'm now suspecting the drive shaft or intermediate shaft, or possibly the gear teeth on the right side.
According to a sensitive female witness, this noise had actually been occurring for some time before the wheel bearing sound, but the driver hadn't noticed it.
Can someone confirm my suspicion?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 30-08-2026, 13:38.
pax
Avatar-pax
2000 Volkswagen Passat
Post06-09-2009, 12:22    Subject: Torque Wrench 27Nm: Troubleshooting Noise Issues Quote
For the Sharan, the torque is 150 Nm and the angle is 90 degrees.
Bye.
peace
Translated on 30-08-2026, 13:40.
No new posts TDI Audi 80: Replace Crankshaft Position Sensor? Diesel Engine Technology
No new posts Properly tightening the KW central screw in the AKE? Diesel Engine Technology
No new posts VP37 Cable Screw: Alternative to Hex Head Screw Diesel Engine Technology
No new posts Torque Specs: Alloy Wheel Lug Nut Tightening Transmission, Chassis, Body & Interior
