Hi there,
Attached you will find a suggestion for an instruction manual that makes adjusting the flow rate setting on the VP37 a little easier. I have personally used it successfully several times.
However, since not all VP37 models may be exactly the same, I would like to present this guide for discussion first. Suggestions and additions are welcome.
Possibly, they can then be added to the repair manuals.
| Description: |
| Adjustment aid for the quantity setting device on the VP37 |
 Download |
| File name: |
Justierhilfe für MSW auf der VP 37 .pdf |
| File size: |
280.11 KB |
| Downloaded: |
10410 times |
Translated on 17-07-2026, 18:39.
