Turbo-Nachlauf beim TDI - notwendig, sinnvoll, Maerchen? | Posts 16+
Go to page: Previous  1, 2
donalexo
Post05-05-2003, 18:43    Subject: Quote
Hello everyone!
Those who don't like it can just buy a vacuum cleaner; it's less noisy there, but it's also not good for the engine...
I can only confirm this from my experience with VW Bullies (T2, 1.7D). In the disabled transportation service, these little engines were only moved digitally, without any regard for wear and tear.
The result was a large number of cylinder head gasket failures, often accompanied by an additional crack in the cylinder head. And these are naturally aspirated engines, to be noted!
Conclusion: A sensible approach has never damaged an engine. That means: warm it up properly first, then put it under load, and after a period of high load, allow it to return to its thermal equilibrium before turning off the machine, right?!
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 12-09-2026, 9:18.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LT35: AHD (102 hp) to AUH (158 hp) swap - worth it? Diesel Engine Technology
No new posts Out-of-Tolerance Lag: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Wheel Alignment: Compensation, Offset, Caster Transmission, Chassis, Body & Interior
No new posts Coolant Pump Strategy for CBBB System 2. On-Board Diagnostics (OBD)
