zipzilla Guest
21-05-2002, 20:36 Subject: Rear door won't open |
hello,
My friend has an A3, and the rear hatch won't open! I've tried all the key tricks, but nothing works. Her trusted Audi partner suggested drilling a hole, but not where?
Best regards.
zipzilla
TL;-) Guest
21-05-2002, 21:49 Subject: Rear door won't open |
'cannot be opened anymore' If the key no longer fits in the lock, the locking mechanism cannot be activated, or is the tailgate simply 'stuck' despite the preceding symptoms?
Thorsten.
zipzilla Guest
23-05-2002, 17:19 Subject: Rear door won't open |
hello,
You can turn the key in the lock, lock it, etc., but the tailgate won't open. It's as if the mechanism inside, behind the paneling, is broken or something.
Best regards.
zipzilla
Joined: 04/12/2002 Posts: 18068 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
23-05-2002, 17:33 Subject: From the inside... |
...one would need to access the lock mechanism. Checked a Ford Focus, manufactured in July 1998.
Fold down the rear seat and remove the shelf.
There is a recessed handle in the tailgate, and inside this recess are two Phillips head screws.
Remove the screws and then gently pull on the grip indentation.
The plastic part is just clipped in, so it should be removable.
Now, with some maneuvering and a flashlight, it should be possible to unlock the lock.
Profile PM WWW Garage |
zipzilla Guest
24-05-2002, 22:03 Subject: Rear door won't open |
hello rainer k.,
but you also can't explain where exactly the Audi wants to drill a hole.
and what about any possible goodwill arrangements in this case? the car is 5 years old!
zipzilla
24-05-2002, 22:08 Subject: Rear door won't open |
Hmm, I have no idea, I wouldn't drill anything there.
zipzilla Guest
26-05-2002, 10:57 Subject: Rear door won't open |
hello rainer,
And what do you think about goodwill arrangements? I mean, shouldn't they still be compensated to some extent, especially if Audi wants to 'drill a hole' (i.e., cause financial damage) in the process?
Best regards.
zipzilla
27-05-2002, 10:10 Subject: Rear door won't open |
Hi, I don't think Audi will be very interested in what I think.
Either you negotiate to have the entire thing repaired for free, or I won't accept holes in the cover due to paint and rust. Otherwise, you can remove the two Phillips head screws and pull on the inner panel to see what's going on.
zipzilla Guest
27-05-2002, 17:27 Subject: Rear door won't open |
hello,
Okay, I will do that. Thank you very much for the information.
Best regards.
zipzilla
