reuselkopp Blaumann
17-09-2009, 7:14 Subject: |
Moshe,
Yesterday, I worked on the nut with the angle grinder and file. The nut works, but I can't get the bolt loose  . The guy who changed the shock absorbers probably really tightened it with his impact wrench. I will try again later today.
Greetings.
Reuselkopp. Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 05-07-2026, 10:43.
17-09-2009, 7:27 Subject: |
Anyone who uses an impact wrench to tighten nuts, and does so in a way that overtightens them, deserves to be hit.
They just sort of shoot at it and that's good enough.
When it comes to suspension, brake, and engine components, I prefer to rely on my collection of torque wrenches.
m; Transparency, Teamwork
Translated on 05-07-2026, 10:44.
Profile PM Garage |
Tribu Blaumann
17-09-2009, 8:12 Subject: |
Please don't hit me too hard  .
... but you can manually turn them and then use a screwdriver. I've never had any problems with that.
Translated on 05-07-2026, 10:45.
reuselkopp Blaumann
18-09-2009, 6:31 Subject: |
Hello.
Okay, so I got the hat nut yesterday.
But the mother underneath, who was holding everything together, was solid as a rock; nothing had come loose  .
I investigated it further, and I think the noise is either coming from the strut mount or directly from the shock absorber. I'll order new strut mounts for now. When disassembling the shock absorber, I can then check if the problem is with the shock absorber itself or just with the bearing.
I was planning to buy Febi Bilstein replacement parts. Are they of good quality? I don't want to install some cheap, low-quality stuff again that will break down after only three months.
Is there a way to avoid having to realign the track again?
Greetings.
Translated on 05-07-2026, 10:46.
Tribu Blaumann
18-09-2009, 8:05 Subject: |
Hi there...
Yes, the bearings are good. You don't need to adjust the alignment if you remove the spindle (3 screws) and the axle nut. Leave the damper screws alone. Unlike the Golf IV, there's no play in the components of the 3-series, which means you can't adjust anything.
Translated on 05-07-2026, 10:47.
reuselkopp Blaumann
18-09-2009, 8:55 Subject: |
"Oh, that's a good idea, but there's just one catch." My torque wrenches only go up to a maximum of 125 Nm, which is unfortunately far too low for the axle nut.
Greetings.
Translated on 05-07-2026, 10:48.
christians Profi-Schrauber
18-09-2009, 11:45 Subject: |
A body scale and a calculator can sometimes replace a 3/4" torque wrench. Gruß Christian
Translated on 05-07-2026, 10:49.
Tribu Blaumann
18-09-2009, 22:49 Subject: |
Well, a torque wrench doesn't cost a fortune either (plus 19 euros at Top and Tip, up to 290 Nm, I think). I think one is enough for personal use, as it's free.
Wheel bearings or not, I used to always do it without them before, and it never caused any problems.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
19-09-2009, 9:16 Subject: |
As a DIY enthusiast, you'll need that tool for your entire life.
Okay, buy something decent and good, with a 10-year warranty. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 05-07-2026, 10:50.
Profile PM Email Garage |
reuselkopp Blaumann
10-10-2009, 8:29 Subject: |
Hello everyone,
Since I don't have a large torque wrench, I had an idea. Could the axle nut also be tightened to 125 Nm, which my small Hazet wrench can handle, and then, for example, tightened another 2 x 90 degrees? Would that correspond to approximately 265 Nm? There are instructions and vehicles where this is done in this way.
Greetings.
10-10-2009, 19:03 Subject: |
That would be a coincidence. As I mentioned before, determine your body weight and calculate the lever arm needed to achieve 265 Nm of torque when you are standing on the tool. Gruß Christian
Translated on 05-07-2026, 10:51.
