Cannot find the list of measurement data blocks in the database
dokatoto
Post10-05-2003, 11:48    Subject: Cannot find the list of measurement data blocks in the database Quote
Can someone perhaps give me a hint? The search function isn't helping either!
Thank you new_all_coholic.gif.
Translated on 19-07-2026, 11:13.
Post10-05-2003, 14:08    Subject: Cannot find the list of measurement data blocks in the database Quote
Hi.
Are you looking for this?
http://www.dieselschrauber.de/Solldaten_Main.html
Translated on 19-07-2026, 11:14.
dokatoto
Post10-05-2003, 14:38    Subject: Cannot find the list of measurement data blocks in the database Quote
No, I already have those.
Please provide the German text you would like me to translate into English. I will then provide only the translation, without any explanations or additional information.
According to the forum, it should be in the error database, but I can't find anything there.
Toto.
Post10-05-2003, 14:52    Subject: Cannot find the list of measurement data blocks in the database Quote
dokatoto wrote:
Instead, provide a listing of the individual measurement blocks in VAG-Com and their function.
Hi.
The values displayed there also appear in VAGCOM icon_idea.gif when the corresponding blocks are selected.
If you're referring to a collection of so-called "label files" that add motor-specific field labels to all readable blocks of data...
I once suggested that in the forum, but I don't think there was enough interest to make the effort worthwhile.
Translated on 19-07-2026, 11:16.
dokatoto
Post10-05-2003, 17:24    Subject: Cannot find the list of measurement data blocks in the database Quote
and how do I know which number corresponds to which block and which function?
Do I have to go through all of them until I find the value, for example, that matches the RPM reading on my T3 tachometer...? etc.?
Translated on 19-07-2026, 11:17.
Post10-05-2003, 19:36    Subject: Cannot find the list of measurement data blocks in the database Quote
Do I have to go through all of them until I find, for example, the RPM value needed to match my T3 tachometer...?
Hi.
If you want to open the measuring blocks with VAGCOM, you must first enter a block number.
Then you will usually see 4 fields containing the information that is also described in the link mentioned above (for the relevant section).
If you have a suitable label file, it will even show you what is displayed under each field... just give it a try.
Translated on 19-07-2026, 11:18.
dokatoto
Post11-05-2003, 7:46    Subject: Cannot find the list of measurement data blocks in the database Quote
That's what I meant. Can you roughly say where the numbers start and end?
Translated on 19-07-2026, 11:19.
Post11-05-2003, 18:50    Subject: Cannot find the list of measurement data blocks in the database Quote
dokatoto wrote:
that's what I meant, can we roughly say where the numbers start and end?
The field numbers are 10 (for group 000) or 4 (for all other groups).
The group numbers can range into the hundreds depending on the engine type, and many of these slots may be unoccupied.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
