BLS, very high charging pressure during regeneration
Post16-03-2010, 19:58    Subject: BLS, very high charging pressure during regeneration Quote
Hi.
Take a look at the boost pressure of a regenerating BLS (Battery Load Simulator) when you give it gas while it's stationary (this noticeable peak in the middle - I still can't use Excel 2007 properly).
Why is he so inflexible when it comes to the boost pressure?
Possibly, a forced regulation icon_wink.gif would be perfect for leak testing while the system is stationary.
 File size:  29.37 KB
 Viewed:  1101 times
 File size:  32.47 KB
 Viewed:  1366 times
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Problem with idle during regeneration Diesel Engine Technology
No new posts Passat 3B 4Motion: Wobbly, Breaks Loose When Braking Transmission, Chassis, Body & Interior
No new posts Parking Heater Smoking: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts 2.5 TDI AEL: Slow Performance & How to Fix It Diesel Engine Technology
