ABS Rings Installation on Drum Brakes
bindpe
Karma: +5 / -2   Thank you, like it!
Post30-03-2010, 17:30    Subject: ABS Rings Installation on Drum Brakes Quote
Hello.
My wheel bearings are pretty worn out after 310,000 km. So, I took the opportunity to get new brake drums as well, since they were already looking quite worn out during the last brake pad change.
Okay, here's the translation:
"Now, to my question: how can I install the ABS rings "gently"? Is there a trick to it? Should I cool the drum, heat the rings, use lubricant, or use a screwdriver...?"
I had the tires replaced about 40,000 km ago, and if they're still in good condition, which I think they are, I'd like to keep them. What do you think?
Thank you for the tips.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 22-09-2026, 23:12.
Post30-03-2010, 18:19    Subject: ABS Rings Installation on Drum Brakes Quote
Just place a thick piece of metal on top of the entire ring and gently tap it with a rubber mallet. They're not usually that difficult to get on.
Translated on 22-09-2026, 23:13.
bindpe
Post30-03-2010, 19:14    Subject: ABS Rings Installation on Drum Brakes Quote
hello
Thank you for the quick reply; sometimes, you just think too complicated icon_smile.gif.
I'd like to finish assembling the drum now. Can you tell me which way I need to press the rotor in?
Does the "plane" surface face the drum brake or the other way around?
"Thank you."
Spritmonitor.de
Translated on 22-09-2026, 23:14.
No new posts Doku Caddy 9K: Drum Brake Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Fuel Filter O-Rings: AHF Replacement Guide Diesel Engine Technology
No new posts ABS Rings Rear Audi A4 1997 Transmission, Chassis, Body & Interior
No new posts Drum Brake Squeal: Causes & Fixes Transmission, Chassis, Body & Interior
No new posts Drum brakes on my Polo 9N3 are driving me crazy! Transmission, Chassis, Body & Interior
