eServo Adaptation: How to Use VCDS
Post29-03-2010, 23:30    Subject: eServo Adaptation: How to Use VCDS Quote
Compared to the 1K-3C, I initially thought that the servo characteristics were fixed and linked to the part number.
Now that I have a 3C Sportline with 17" wheels from the factory and a 3C Comfortline with 16" wheels, I noticed:
Comfortline:
Code:
Adresse 44: Lenkhilfe        Labeldatei: RKS\1Kx-909-14x.lbl
   Teilenummer: 1K1 909 144 L
   Bauteil: EPS_ZFLS Kl.135 H07 1806
   Betriebsnr.: WSC 02069 000 90108
Kein(e) Fehler gefunden.
Sportline:
Code:
   Bauteil: EPS_ZFLS Kl.136 H07 1806
and the CL is easier to maneuver in winter conditions with the same winter tires.
But how can I change the characteristic curves?
Translated on 31-10-2026, 23:52.
Post30-03-2010, 8:12    Subject: eServo Adaptation: How to Use VCDS Translating...
[Translating...]
http://de.openobd.org/vw/passat_3c.htm#44
Post30-03-2010, 19:56    Subject: eServo Adaptation: How to Use VCDS Quote
Yes.
I'm surprised that Sebastian knows that, but he must have forgotten about it when he was writing the LBL files.
Because VCDS doesn't offer it, as A001 is not included.
And there's a good reason for that, because it simply doesn't work.
Translated on 31-10-2026, 23:53.
Post30-03-2010, 22:20    Subject: eServo Adaptation: How to Use VCDS Quote
And there's a good reason for that, because it's not about.
Hmm, maybe a login is required first? But who has access to it?
Translated on 31-10-2026, 23:54.
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Contour Lines: Definition & Calculation Diesel Engine Technology
No new posts eServo: How Long Does It Last? Transmission, Chassis, Body & Interior
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
