dokatoto wrote: |
| I can rule out a turbocharger because I don't have any significant oil consumption. |
Hi Toto,
Then you can also rule out the piston rings and crankshaft seals, as these are often associated with increased oil consumption.
dokatoto wrote: |
| But especially in the first two gears, it really smokes from the back. |
Please use the search function and look for "VTG", "EGR (Exhaust Gas Recirculation)", and "fuel injectors". I assume a verschandeln air filter and unimpeded, bubble-free airflow in the fuel system.
