Passat 35i ECU: Can it work on a Golf 3?
philipp_t4
Post11-04-2010, 19:05    Subject: Passat 35i ECU: Can it work on a Golf 3? Quote
Hello everyone,
I'm currently in the process of converting my T4 to a 1.9 TDI 1Z engine. The engine is from a Golf 3.
Okay, I'm having a problem with the engine control unit (ECU). My ECU from the Golf 3 has an immobilizer, but I can't use it. It's possible to have the immobilizer removed from the ECU, which costs around 100 euros. However, I know someone who would be willing to swap my ECU with his from a Passat 35i facelift model that doesn't have an immobilizer. Is that possible? My engine is from 1994, and the Passat is also from 1994.
It would be great if I could save icon_smile.gif that 100 euros.
Oh yeah, before anyone starts complaining about the WFS: My T4 is a 1994 model and also doesn't have WFS, so it should be fine icon_smile.gif.
Edit: I now also have the part numbers:
Passat: 028 906 021 B
Golf: 028 906 021 AF
Thank you and best regards,
Philipp.
Translated on 22-10-2026, 10:40.
Pfusch und Fünfg'rad
Post30-04-2010, 11:35    Subject: Passat 35i ECU: Can it work on a Golf 3? Quote
According to some forums, the 021B control unit was installed in Switzerland/Austria and does not have WFS (Wireless Functionality System). It should work with any 1Z model. It may be necessary to adapt the connector (only the coding in the corners, not electrically).
After that, check the error memory. An external height sensor might be necessary, as the one in the AF unit is internal.
Otherwise, I would simply take the key reader coil and the WFS control unit from a scrapped vehicle (or from this auction house, which would then need to be programmed) and mount them somewhere in the engine compartment (protected from heat and water splashes, of course). Then, I would connect them to the wiring harness and use the transponder from the original Golf key. For example, I would glue the transponder to the key reader coil using a two-component adhesive (a high-quality one, because if the transponder comes off, it's game over). Then, everything should be fine for the MST, and you can start the T4 with a push button.
Stefan.
Translated on 22-10-2026, 10:42.
Post30-04-2010, 17:19    Subject: Passat 35i ECU: Can it work on a Golf 3? Quote
The part number 028 906 021 B should only be used with the Passat model that has the 1Z chassis code. Therefore, you need to obtain the pin assignments for both the Golf and Passat Message Control Units (MSG) and adjust them accordingly.
Translated on 22-10-2026, 10:44.
No new posts Workshop action: Incorrect coding on VW Golf/Passat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Injection Tuning: VW Passat 81kW AFN Diesel Engine Technology
No new posts Run AXR without LLM Diesel Engine Technology
No new posts Operating AFN with AHU/1Z Injection Pump Diesel Engine Technology
No new posts Operating the RCD 300 externally Electrical Systems, Vehicle Electronics, Multimedia
