Octavia 1 - Querlenkerbuchsen / Federbeintausch > Problem | Posts 48+
Go to page: Previous  1, 2, 3, 4
Octavia_4x4
Post22-06-2010, 9:17    Subject: Quote
Okay, let me see... In my case, the drop isn't that significant, so 1° should be adjustable using the adjustable eyepieces...
"Apparently, VW has a solution where they suggest swapping the upper and lower struts to correct a deviation of around 3 degrees (negative camber), which should bring the alignment close to neutral... I'll take a look."
Octavia_4x4
Post26-06-2010, 7:39    Subject: Quote
Okay, so it turned out to be the bushings... I put the original ones back in, and the vibration is gone. Therefore, I would advise against pressing full rubber bushings into the metal control arms, unless you're okay with the vibration. For me, the risk of vibration-related consequential damage was too high.
The good thing was that after that, when aligning the track, it fit perfectly without any adjustments, a lucky coincidence.
Post26-06-2010, 8:41    Subject: Quote
Octavia_4x4 wrote:
... therefore, I would advise everyone against pressing full rubber bushings into the control arm ball joints...
Right, that's why I bought the cast control arms from the R32. icon_wink.gif
Octavia_4x4
Post26-06-2010, 15:28    Subject: Quote
yes.
"If I'm going to do something, I'm going to do it properly. I agree with you. My idea about reducing weight wasn't really working, I tried it... but I have to say, the comfortable ride it has now is also a plus."
and hopefully, the sockets will last for 2 years icon_smile.gif.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Control Arm Bushings: Improve Performance & Handling Transmission, Chassis, Body & Interior
No new posts Octavia RS TFSI: Top Speed Problem (2008) On-Board Diagnostics (OBD)
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts Log BKD Octavia 2.0 TDI Upload
