BremsRubbeln - was muss neu | Posts 16+
Go to page: Previous  1, 2
Post16-07-2010, 6:29    Subject: Quote
"Never install new rotors with old brake pads. I would never do that; those few euros are well spent on the brakes. Then you'll have peace of mind."
Translated on 14-09-2026, 8:14.
Post19-07-2010, 8:43    Subject: Quote
Okay, please provide the text you would like me to translate from German to English.
I have 2 slices, 4 toppings, and a few percent [of something].
Does it involve applying any ceramic paste, or are they now completely installed dry?
Is the protective coating on the glass only removed at the point of contact?
Is the investment in the hub still protected?
Translated on 14-09-2026, 8:15.
Post19-07-2010, 9:53    Subject: Quote
The silver protective coating on the original windows is no longer removed.
Post19-07-2010, 12:15    Subject: Quote
Aunt Elsa says that you should remove it.
haithamina
Post19-07-2010, 13:15    Subject: Quote
@ dieselmartin
My own experience shows that it disappears immediately when braking and doesn't cause any problems with the brake pads.
Furthermore, only the surface area is actually cleaned, which will likely not prevent the rest of the brake disc and pads from rusting over time.
Let him do it and go for a ride.
haithamina
Translated on 14-09-2026, 8:16.
R.M.
Karma: +14 / -0   Thank you, like it!
Post19-07-2010, 13:53    Subject: Quote
I left it on there too (I replaced the brake pads on both the front and rear axles at the same time). For a week or two, you could still see small pieces of the rolled-up paint on the caliper, but they eventually disappeared. The braking performance was always good.
Translated on 14-09-2026, 8:17.
Post19-07-2010, 15:04    Subject: Quote
Does anyone know where to find ceramic paste?
I would have applied a coating to the sliding edges of the flooring guides.
Possibly also the back sides of the tiles.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-07-2010, 15:45    Subject: Quote
Hello Martin, you can easily apply ceramic paste to the surface of the plates. However, I usually do it with a small brush in the plate carrier, as the carrier itself comes down and needs to be cleaned.
The back of the flooring is often already coated, but it's not a mistake to apply another coat.
Currently, I'm receiving the Zimmermann brake discs (with the last two digits being -20 instead of -00) that are coated like the original equipment (OE) discs, and I haven't had them sanded. The coating provides quick braking performance on the friction surface, and the rest of the disc, including the edges, remains protected, which isn't as effective when the discs are sanded.
The silver coating is, in my opinion, not paint, but rather an aluminum or zinc layer.
If the noise from the rubbing is bothersome, as your comment suggests, I would replace everything and not compromise on quality for the sake of longevity.
Translation: "However, it could still be a wheel bearing."
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 14-09-2026, 8:18.
Post19-07-2010, 15:51    Subject: Quote
I don't want to hope for wheel bearings, because I just have a complete set of brakes (2 discs, 4 pads) here.
On the other hand, I'll know for sure then.
Translated on 14-09-2026, 8:20.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-07-2010, 16:45    Subject: Quote
You can always use brakes - I also have plenty lying around icon_lol.gif.
Trial and error. Go for it.
Karma: +1100 / -0   Thank you, like it!
Post19-07-2010, 17:08    Subject: Quote
I will get back to you in about 3 years... icon_wink.gif Given my current almost exclusive use of highways, the material seems to last forever!
Translated on 14-09-2026, 8:21.
Post20-07-2010, 8:10    Subject: Quote
Versuch und Irrtum. Put some music on.
That's how I do it too.
Because, as mentioned, the windshields are 126,000 kilometers old and are very close to the end of their service life.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post20-07-2010, 9:21    Subject: Quote
I'm always wondering what the disc will look like after another 30,000 km. If it's only 1 mm below the minimum thickness, it will be replaced, unless a cost-effective repair is possible to extend its lifespan for the remaining half-year of its inspection validity.
But you have a nice car, and it's also fast.
Translated on 14-09-2026, 8:22.
Post24-07-2010, 15:03    Subject: Quote
The rotors and pads are new.
icon_arrow.gif everything is fine. The scratching is gone.
Thank you for all the suggestions.
No new posts VAG-COM: Interpreting LMM Values - A Guide Diesel Engine Technology
No new posts ECU Tuning: What needs adjusting? Diesel Engine Technology
No new posts ECU needs to be reprogrammed??? On-Board Diagnostics (OBD)
No new posts VTG Rod Adjustment: VNT17 Installation Guide Diesel Engine Technology
