somewhat off-topic: how much pressure can a radiator withstand?
eike
Post05-06-2003, 7:24    Subject: somewhat off-topic: how much pressure can a radiator withstand? Quote
Hi everyone,
Due to the current heat, I had the idea to build a makeshift air conditioner using a car radiator. I would run the water from the well pump (around 8-10°C) through the radiator and then to the garden sprinkler. The radiator would be placed in the apartment and connected with hoses. Before the radiator, I would place a fan that would then blow the air through it. Under the cooler, a small basin is placed, which collects the condensation water.
The question that now arises for me is, how much overpressure can such an automotive radiator withstand. The pump produces approximately 3-5 bar. Not that the part will burst or leak.
Does anyone here know exactly, for example, what the pressure conditions are in the car at a coolant temperature of 120°C? He should be able to handle it.
Greetings
Eike
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post05-06-2003, 8:20    Subject: somewhat off-topic: how much pressure can a radiator withstand? Quote
The idea is great http://home.t-online.de/home/bullitt667/smilies/data/uglyspitze.gif
I had a similar idea for my room, but instead of connecting the water directly to the boiler, I would have redirected it.
I believe that it will only withstand up to approximately 1 bar.
But if the garden sprinkler is connected at the end,
The pressure should definitely not exceed 1 bar.
Gremlin
Post05-06-2003, 11:28    Subject: somewhat off-topic: how much pressure can a radiator withstand? Quote
'Therefore, the cooling system can be drained with a maximum pressure of 1 bar.'
if I still have it right in my head, the deck vent valves will close at 1 - 1.2 bar.
'I would definitely not give 5 bar to a cooler. Instead, I would prefer to use a feed pump with <= 1 bar and then run the pressure pump only after the cooler.'
btw: I like the idea, but unfortunately I don't have a well icon_sad.gif
See you, Gremlin
Helmut
Post10-06-2003, 22:41    Subject: How much pressure can a radiator withstand? Quote
Hello Eike,
Still going off-topic, but I'll be back soon:
Take a condenser from an air conditioner; I have a condenser from a refrigerator in the attic. Fan and condensate collection are already included.
Greetings
Helmut
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM! How much more power can it handle? Diesel Engine Technology
No new posts AKU engine size: How many cc? Diesel Engine Technology
No new posts KGE: How much oil leakage is normal? Diesel Engine Technology
No new posts Turbocharger Pressure: How Much Is Too Much? Diesel Engine Technology
