Could there be a bug in the current version?
MKB: BCB
Label file: RKS\036-906-034-AZD.lbl
Control unit part number: 036 906 034 DR.
Component and/or version: MARELLI 4MV 5957
Encoding: 00031
Company number: WSC 72257
MWB: 30
"I am seeing the following:"
Lambda control (oxygen sensor status).
Bank 1, Probe 1, 000.
Bank 1, Probe 2, 100.
and after about 1 minute.
Bank 1, Probe 2, 110.
[img]/download.php?id=4622[/img]
Normally, probe 1 is the upstream probe and probe 2 is the downstream probe.
However, the upstream oxygen sensor is initially activated at 100 degrees Celsius at engine start and then at 110 degrees Celsius after 1 minute, while the downstream oxygen sensor is only activated much later. Or have I made a mistake in my thinking?
