Passat 3C 2.0: Glow Plug Light Flashing, Limp Mode
la gringo
Post05-12-2010, 10:49    Subject: Passat 3C 2.0: Glow Plug Light Flashing, Limp Mode Quote
Hello everyone.
I'm having the following problem with my Passat 2.0 TDI BMR 170hp DPF:
The preheating indicator light would sometimes flash, and the car would go into emergency mode. After turning it off and restarting, everything would be okay again.
Three weeks ago, after a few consecutive starts, the warning light remained on continuously, and it has been like that ever since. The car is now constantly running in limp mode.
After visiting all the workshops in my area, and having no luck, I'm reaching out to you because I'm really at a loss.
"The car has been scanned multiple times, and the error memory is clear!!!"
I would be grateful for any help. I have experience as a bicycle mechanic, so I'm familiar with technical aspects.
Translated on 08-09-2026, 20:51.
Post05-12-2010, 11:40    Subject: Passat 3C: Glow Plug Light Flashing - Troubleshooting Quote
la gringo wrote:
THE CAR WAS DIAGNOSED ONCE AND THE FAULT MEMORY IS EMPTY!!!
It's impossible if the light is on. Find another workshop, go to the dealership, or buy VCDS and find the error yourself. Otherwise, nothing will change.
Translated on 08-09-2026, 20:53.
Deus Violentia
Post05-12-2010, 12:02    Subject: Passat 3C 2.0: Glow Plug Light Flashing, Limp Mode Quote
That's possible! Specifically, this happens when someone has removed the DPF (Diesel Particulate Filter) from the system. In such cases, the error code display is often completely disabled.
BKD GRF
AHF EBF
Translated on 08-09-2026, 20:54.
la gringo
Post05-12-2010, 12:17    Subject: Passat 3C 2.0: Glow Plug Light Flashing, Limp Mode Quote
Okay, so I've already been to the mechanic four times... they replaced and adjusted the differential pressure sensor.
At some point, the DPF warning light came on, along with the engine check light.
"Errors found: DPF efficiency below minimum and intake manifold flap."
The DPF is 20% clogged, which is still within the acceptable range.
"However, this error has been successfully cleared... VW now wants to test the entire wiring harness, which would involve significant costs."
and somehow, it just can't be... I suspect it's some kind of relay or other electronic component, maybe a sensor...?
Initially, the error was intermittent as described, but now it occurs constantly.
Translated on 08-09-2026, 20:55.
Post05-12-2010, 14:15    Subject: Passat 3C 2.0: Glow Plug Light Flashing, Limp Mode Quote
The DPF is 20% loaded, so it's still within the green range...
Assuming that you haven't made any typos here, it's nonsense.
The BMR (likely referring to a percentage value) indicates the loading level, which decreases from approximately 40% back to 0% through a regeneration process (this typically occurs after about 400 km). This means that the percentage value changes even after just 2 km.
You probably mean 20 grams of ash content.
Sure, I will pay close attention to avoid any errors. Please provide the text you would like me to translate from German to English.
If everything else is original, I also don't believe in the idea of "no errors in memory."
Translated on 08-09-2026, 20:56.
Post05-12-2010, 21:57    Subject: Passat 3C 2.0: Glow Plug Light Flashing, Limp Mode Quote
Reading the error codes correctly... that's all there is to say about it.
Translated on 08-09-2026, 20:57.
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Climatronic display blinking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light flashing - ASZ TDI PD Diesel Engine Technology
No new posts Power Cord/Glow Plug Flashing: Troubleshooting Diesel Engine Technology
No new posts Audi A6 2.5 TDI, Preheat lamp flashing (AAT) On-Board Diagnostics (OBD)
No new posts Glow Plug Light Flashing: DPF & Engine Error Codes Diesel Engine Technology
