Radio concert in A3 8P, squealing/poor sound
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post06-12-2010, 20:57    Subject: Radio concert in A3 8P, squealing/poor sound Quote
In my A3 8P, I have a Concert radio, but unfortunately, the sound quality is terrible. The radio and CD player crackle and hiss at even slightly higher volumes, and you constantly hear popping and crackling noises. The sound can be described as "gritty."
Since this hasn't always been the case, I wonder what might have gone wrong. The warranty is becoming difficult to claim, as everything actually works, it just sounds bad.
Is there a known standard error? Are there issues with fuses, or are the radio's electrical components simply of poor quality?
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post06-12-2010, 21:18    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Hi Rainer,
The speakers themselves can also cause a slight change in sound, depending on their temperature.
reflexsilber met.
Post06-12-2010, 21:42    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Hm, they should have gotten warm enough by now... in the other car, it sounds much better despite the "inferior" system. icon_question.gif
RedR32
Avatar-RedR32
Post06-12-2010, 22:13    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Ibiza 4 (sound): The absolute last bit... sounds totally tinny.
My Leon - 8 speakers - perfectly tuned together.
Now, the shopping bags are empty for testing purposes...
Or did you change the radio settings or remove the battery?
reflexsilber met.
Post06-12-2010, 22:16    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Now, but the shopping bags are already empty for testing purposes...
Or radio settings changed, battery disconnected?
Karma: +1102 / -0   Thank you, like it!
Post07-12-2010, 7:19    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Depending on the location where the speakers are installed, it may take longer for the heat to reach them. I seem to recall Ulf mentioning a lack of bass when the car was freezing cold. The stiffening of the surround and cone due to the cold can significantly hinder the movement of the diaphragm. Putting in more effort doesn't necessarily achieve the desired result.
Currently, I'm also missing the front 16cm subwoofers, and I won't install them until I can achieve reasonably comfortable temperatures inside my "Bummsmurmel" (a playful, informal term for a large speaker enclosure). The rear 13cm subwoofers will even take longer. But at least I don't snore; I just don't have any bass at the beginning.
Post07-12-2010, 8:54    Subject: Re: Radio concert in A3 8P - squealing/poor sound quality Quote
dieselschrauber wrote:
The radio and CD player are making crackling and popping noises, even at a slightly higher volume, and it feels like there are constant crackles and hisses. The sound can be described as "gritty."
Since this hasn't always been the case, I wonder what might have gone wrong. . .
Could dust particles have gotten into the air gap around the coil windings?
Then it probably didn't happen at exactly the same time for all the Cassis. -> Try using the balance control and fader to see if all channels are affected equally icon_wink.gif.
Post07-12-2010, 10:33    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Then it probably didn't happen at exactly the same time for all the Cassis. -> Try using the balance control and fader to see if all channels are affected equally.
It is always the same, regardless of whether it's VL, VR, HL, or HR.
Post07-12-2010, 10:50    Subject: Radio concert in A3 8P, squealing/poor sound Quote
OK, then there must be a common cause for all channels.
Okay, I'll start by checking the power supply section.
board-side -> Positive and ground cables + connector, fuse...
internal -> connector, circuit board, filter components...
Post07-12-2010, 11:12    Subject: Radio concert in A3 8P, squealing/poor sound Quote
"Hutfahrer" seems to be right; this morning, the temperature was +8°C instead of -7°C, and the sound was much better. icon_eek.gif The question is, why do the speakers in the two cars react to the cold so differently?
Post07-12-2010, 11:56    Subject: Radio concert in A3 8P, squealing/poor sound Quote
A matter of material selection... icon_wink.gif Dipped cardboard sticks and cotton centering elements make less of a difference than those made of rubber.
What kind of high-end components are installed? My speakers tend to sound sharp at high frequencies, which is made even worse by the lack of bass.
Post07-12-2010, 13:05    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Please provide the text you would like me to translate from German to English.
"Hutfahrer" seems to be right; this morning, it was +8°C instead of -7°C, and the sound was much better. icon_eek.gif The question is, why do the speakers in the two cars react so differently to the cold?
Moisture in the area of movement of the speaker cones forms ice particles that make a creaking sound below 0°C. icon_wink.gif
In our Ibiza 6K GP01, the water drainage hole of the left door's woofer was so clogged (possibly from the factory) that the system would regularly flood. The flooding was so severe that a clear waterline was visible, and mold had already started to grow below the membrane and bead.
Since the Ibiza in question was also a car owned by a woman, I probably didn't have the opportunity to hear any suspicious sounds from that low-mounted speaker in the door when the water bag was frozen.
Post07-12-2010, 13:07    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Post07-12-2010, 14:36    Subject: Radio concert in A3 8P, squealing/poor sound Quote
Hutfahrer wrote:
Strangely, it didn't even smell that much that my significant other mentioned it. icon_eek.gif
And men, well, they just don't smell anything compared to women...
However, the entire surface appeared to have been so dry for years that mold only grew on the back of the membrane (which was visible). And the unpleasant smell from the back probably remained mostly trapped inside the glove compartment...
Octavia_4x4
Post31-12-2010, 9:34    Subject: Radio concert in A3 8P, squealing/poor sound Quote
I can confirm that issue with the sound quality being worse when it's cold in my Skoda, especially the lack of bass. However, after listening at a slightly louder volume for a few minutes, it then starts to work icon_smile.gif.
Post31-12-2010, 21:28    Subject: Radio concert in A3 8P, squealing/poor sound Quote
What kind of speakers are installed? My
tend to become sharper when it's cold - which is made even worse by the lack of bass.
No idea, just a series.
No new posts MKB ABC: Engine Start Issues After MSG Replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Radio Issues: Problems When Starting Engine Diesel Engine Technology
No new posts Car Radio No Sound at Startup? Troubleshooting Transmission, Chassis, Body & Interior
No new posts Concert 2 Upgrade: Expand Your System Transmission, Chassis, Body & Interior
No new posts Audio Signals in Concert II: How to Input? Transmission, Chassis, Body & Interior
