Hello!
Today, I finally had time to install the MFL. Everything is wired according to the wiring diagram, with the original fuse location, etc., etc...
I then checked the box for "MFL Installed" under "MFL" in the BMC (Body Control Module), and it started working. I turned the ignition off and on again to see what would happen. Aha, on the right side of the MFA+ (Multi-Function Display), I can switch between the menu levels, but I can't navigate up and down within the menu. On the left side, I can adjust the radio volume and switch between stations. The phone buttons are not working.
Okay, so, ignition off and on again, now I can switch up and down in the MFA+ menu, but I can't navigate between the menu levels like MFA-Radio- etc. anymore. On the left, I can still adjust the radio volume and change stations. The "OK" button... The button in the middle is still non-functional, but if you press the microphone button, the hands-free system suddenly responds: "No device is connected." Wow, the first signs of life from my hands-free system!
Once again, I turned the ignition off and on, and after that, everything basically worked, at least as far as the MFL was concerned.
There's still a lot of silence in the AI field, and the FSE (likely referring to a specific software or feature) isn't showing up for me. When the microphone button is pressed, the word "PHONE" appears on the display of the radio (RCD 310), but nothing else is shown.
I then tried, as a test, to establish a Bluetooth connection between my iPhone 3GS and the car's hands-free system. I get to the point where the PIN is requested, but since there's no display on the screen, I obviously can't see the PIN, so nothing happens.
Okay, here are my questions:
Do the control units need to learn each other's characteristics? Or why were only half of the functions working at the beginning?
How do I set up the display in the AI (artificial intelligence) system?
Attached is a scan from today. The latest error originates from BMC (BNS):
Friday, January 7, 2011, 3:57:48:39957
VCDS Version: RKS 10.6.3
Data as of: 20101206
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 6N0
Scan: 01 03 08 09 10 15 17 18 19 25 2E 56 77
Vehicle Identification Number: WV2ZZZ7HZBH0XXXXX
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-Onboard network -- Status: Error 0010.
10-Parking assist 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
18-Heater -- Status: OK 0000
19-CAN-Gateway -- Status: Error 0010
25-way immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: not logged in 0001
56-Radio -- Status: OK 0000
77-Phone -- Status: not registered 0011
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine (J623-CAAC) Label file: None
Part number SW: 03L 906 022 CH, HW: 03L 907 309 K.
Part: R4 2.0L EDC H37 7538
Revision: 26H37--- Serial Number: 00000000000000
Encoding: 0119401A232400080000
Operating number: WSC 02756 790 50316
ASAM Dataset: EV_ECM20TDI01103L906022CH 002008
ROD: EV_ECM20TDI01103L906022CH.rod
VCID: 6DD45A870D17
No errors found.
Readiness: 0 0 0 0 0
Address 03: Brakes (-----)
Label file: None
Part number SW: 7E0 907 379 G, HW: 7E0 907 379 E.
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Encoding: 108724AD09A7089924A6907A6A6410
Operating number: WSC 02756 790 49152
VCID: 3666B5EB38C1
No errors found.
Address 08: Climate Control/Heating (J301) Label file: 7E5-907-047.clb
Part number SW: 7E5 907 047 AJ Hardware number: 7E5 907 047 AJ
Part: Climatic-T5 H11 0203
Revision: 00005001
Encoding: 0000000002
Operating number: WSC 02757 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaticT5_VN75.rod
VCID: 77F878EF7F4B
No errors found.
Address 09: Body Control (J519) Label file: RKS\7H0-937-08x-09.clb
Part number SW: 7H0 937 087 D, HW: 7H0 937 087.
Component: BCM T5GP H+4 H47 0221
Revision: BO047001 Serial Number: 0347 235100043
Encoding: A0A0393A6E212012012800007C2B9ED50080410F60840000300000000000
Operating number: WSC 02754 790 00000
VCID: 3564B2E725C7
Part number: 1K0 955 559 AH
Component: RLS 010910 05 54 0403
Encoding: 03702E
Part number SW: 7E0 959 801 A, HW: 7E0 959 801 A.
Part: J386__TSG_FT 003 3311
Encoding: 040000
Part number SW: 7E0 959 802 A, HW: 7E0 959 802 A.
Part number: J387__TSG_BT 003 3311
Encoding: 040000
Part number SW: 3C8 959 537 D HW: 3C8 959 537 D
H06 0022
"1 error found:"
01044 - Control unit incorrectly coded.
000 - - - Sporadic
Environmental conditions:
Error status: 00100000
Error priority: 2
Error frequency: 26
Mileage: 0 km
Time: 0
Date: 2003.14.22
Time: 00:00:00
Address 10: Parking Assist 2 (J446) Label file: RKS\7E0-919-475.clb
Part number SW: 7E0 919 475 A, HW: 7E0 919 475 A.
Part: PARKING ASSIST 8K H10 0008
Revision: -------- Serial Number: 32731022501033
Encoding: 100001
ASAM Dataset: EV_VW75XParkAssis8K A01003
ROD: EV_VW75XParkAssis8K.rod
VCID: 306A83F3DAA5
No errors found.
Address 15: Airbag (J234) Label file: 5K0-959-655.clb
Part number SW: 7E0 959 655 C, HW: 7E0 959 655 C.
Part number: VW10Airbag007 H06 0013
Revision: -------- Serial Number: 003HM000BPXP
Encoding: 0000000000000000000000000000000
Operating number: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_VN75.rod
VCID: 3666B5EB38C1
Crash sensor for driver-side side airbag:
Serial number: 3495ZRB40596JIHQ718%
Crash sensor for side airbag, passenger side:
Serial number: 3505ZRB40516JIHQ8OED
No errors found.
Address 17: Combination instrument (J285)
Label file: RKS\5K0-920-xxx-17.clb
Part number SW: 7E0 920 870 C, HW: 7E0 920 870 C.
Component: COMBINATION UNIT H04 0204
Serial number: 00000000000000
Encoding: 160F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_VN75.rod
VCID: 295C6E97F97F
No errors found.
Address 18: Auxiliary heater
Label file: None
Part number: 7E0 815 071 A
Component: J737__Auxiliary Heater 0404
Revision: 00085000 Serial Number: 09019275D00000
Encoding: 0000031
Operating number: WSC 02757 790 00000
VCID: 23407CBF9B53
No errors found.
Address 19: CAN-Gateway (J533) Label file: RKS\6N0-909-901-6R.clb
Part number SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0221
Encoding: 042200
VCID: F0EAC3F39A25
"1 error found:"
000 - -
Error status: 01100000
Error priority: 2
Error frequency: 3
Mileage: 1398 km
Time: 0
Date: 2003.14.13
Time: 14:05:27
Address 25: Immobilizer (J334)
Label file: 5K0-920-xxx-25.clb
Part number SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0204
Serial number:
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VN75.rod
VCID: EADED19BBCF9
No errors found.
Address 2E: Media Player 3 (J650) Label file: RKS\5N0-035-342.lbl
Part number SW: 5N0 035 342 C. Part number HW: 5N0 035 342 C.
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial Number: 7668556460
Encoding: 010000
VCID: 275868AFEF6B
No errors found.
Address 56: Radio (J503) Label file: RKS\5M0-035-1xx-56.clb
Part number SW: 5M0 035 186 AA. Part number HW: 5M0 035 186 AA.
Part: Radio RCD310, part number 016 0049.
Revision: 01000000 Serial Number: VWZ1Z2K7182478
Encoding: 0900040004
VCID: 6BD0549F3303
No errors found.
Address 77: Phone (J412) Label file: RKS\3C8-035-730-A.clb
Part number SW: 3C8 035 730 A, HW: 3C8 035 730 A.
Component: Telephone 007 0078
Revision: -------- Serial Number: 35909603005766
Encoding: 010000010000010000000400
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_VN75.rod
VCID: 214C76B7814F
2 errors found:
9457427 - Negative output audio channel for voice/telephone.
B104F 13 [009] - Interruption.
Error status: 00000001
Error priority: 4
Error frequency: 1
Lost Count: 28
Mileage: 1398 km
Date: 2003.14.13
Time: 14:27:55
9457939 - Bracket for phone holder.
B1051 13 [009] - Interruption.
Error priority: 4
Error frequency: 1
Lost Count: 28
Mileage: 1398 km
Date: 2003.14.13
Time: 14:27:55
End.
Okay, what does the phone system want from me? I've coded it so that under the "Owner" option in the menu, it displays "None" or "Bluetooth." How can I finally tell the hands-free system that there is no owner?
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
