Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post23-01-2011, 14:04    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
Hello
Today, the temperature here was almost -20°C. My Audi was parked outside all night. This morning, I immediately preheated it twice. However, it didn't start until about 5 seconds later? Lately, it seems like it's taking a little longer to start. I've already read out the error codes. The error codes don't show any issues with the glow plugs? Are there even defective glow plugs stored in the memory for this model? Or should I replace the glow plugs after a few years as a standard procedure? Currently, I have approximately 85,000 km on the odometer, manufactured in June 2012.
Thank you for your tips...!
Audi SQ5 8R Cvub
Back to top Profile PM Email
Post23-01-2011, 14:16    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
Yes, they are being monitored.
CR or PPD?
MKB?
pa-mm6
Post23-01-2011, 14:28    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
born in 2007, German market, 2.0L engine, PPD TDI. Do the light bulbs get worse over time? Should I replace them periodically, even if there are no errors in the error memory?
Thank you for your help!
Best regards
tom
Audi SQ5 8R Cvub
Post23-01-2011, 14:41    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
pa-mm6 wrote:
Do incandescent bulbs get worse over time?
Yes, they do. Incandescent bulbs can still function and yet not function. Sounds strange, but that's how it is. icon_biggrin.gif
After 85,000 km, it shouldn't be that bad.
PPDE - Has it been cleaned or replaced?
pa-mm6
Post23-01-2011, 15:02    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
HI,
The PPDs were cleaned at approximately 77,000 km at VAG. Performance has since been restored. I will add another 5 liters of fuel injector cleaner to the tank, hoping that it will prevent them from clogging so quickly... icon_confused.gif
So, ich meine, die Glühbirnen sollten bei deinem Kilometerstand noch nicht ausgetauscht werden?
Audi SQ5 8R Cvub
D.
Post23-01-2011, 19:55    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
In welcher Region waren denn vergangene Nacht -20°?
My Touran, manufactured in 2005, with now 91,000 KM and the 140 PS TDI engine, still starts perfectly - at least when it's cold (although I do experience the warm-up difficulties).
valerrik
Post23-01-2011, 21:34    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
I'm having the same problem! No errors in the memory, but it's jumping around by about 2 degrees, which is really bad. Same engine, etc. 100,000 km on it. I had the PD elements replaced in December.
pa-mm6
Post23-01-2011, 22:13    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
D. wrote:
Which region experienced temperatures of -20°C last night?
In Kitzbühel, it's currently very cold there....
Audi SQ5 8R Cvub
Stummel
Post24-01-2011, 19:45    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
140PS-PPD-TDI, what's up? I thought the PPD parts were only for the 170PS engines? icon_question.gif
Post24-01-2011, 20:37    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
Stummel wrote:
...I thought the PPD parts were only available for the 170hp models? icon_question.gif No, they were also available for the 140hp models.
voodoo
Post31-01-2011, 16:47    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
My information is that PPD only occurred in 170PS (MKB: BRD) engines in the A4 8E.
I have the 140hp (MKB: BPW, 8V) engine and I only have 'standard' PD (direct injection) injectors.
Also, the BLB engines (16V 140PS) also do not have a PPD.
Post31-01-2011, 17:02    Subject: Will the Audi A4 B7 170 PS TDI engine have a problem? Bulbs indicated Quote
I always thought that PPD = 170 horsepower.
But there were indeed 140er PPDs.
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Werkstattaktion 2D, Glühkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 2.5 TDI MWB 4 Injection Timing IS NOT displayed Diesel Engine Technology
No new posts Glühkerzen beim 1z Diesel Engine Technology
No new posts Incandescent bulbs at AUY Diesel Engine Technology
No new posts Stuck Glow Plugs - Audi AEL: How to Fix Diesel Engine Technology
