Passat Heater Not Working: 2000 1.9PD Fix
chli1976
Post02-02-2011, 23:00    Subject: Passat Heater Not Working: 2000 1.9PD Fix Quote
I have a radiator that's not heating up, and I thought it was probably the heating element.
I then tried to clean it with a radiator cleaner. I drove with the cleaner in the system for a day, and then oil started leaking out through the expansion tank.
Okay, so I replaced the oil cooler and added another cleaning agent, but the oil is no longer getting into the water, but it's still not heating up. I then checked the temperature control valve actuator, and it seems to be working. I also disconnected the linkage and manually set it to the "hot" position, but the heating still doesn't work.
I then measured the temperature of the radiator hoses leading to the heater core using an infrared thermometer. I got approximately 75°C on both hoses, but the outlet temperature at the vents was not even lukewarm, but rather cold.
Okay, so I disconnected the small hose on the expansion tank. Only water comes out when I hold it down for a bit, but I tried the same thing on another Passat and it's the same. The water pump was replaced only 5000 km ago.
The only thing that seems strange to me is that when I open the expansion tank and press on the radiator hoses, I don't hear any gurgling. However, I did fill the cooling system under vacuum.
I know that the radiator coolers tend to accumulate scale, but if that's the case, shouldn't the hoses be at different temperatures?
VCDS
Translated on 07-09-2026, 18:11.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post04-02-2011, 20:45    Subject: Passat Heater Not Working: 2000 1.9PD Fix Quote
Can't you disconnect the hoses to the heat exchanger from the engine compartment and blow or flush the heat exchanger to check the flow?
Translated on 07-09-2026, 18:13.
chli1976
Post04-02-2011, 21:41    Subject: Passat Heater Not Working: 2000 1.9PD Fix Quote
Replaced the heating cooler today, and the heating is working again.
VCDS
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts The air conditioner is not heating Transmission, Chassis, Body & Interior
No new posts OBD2 Scanner for VW Passat 2000 PD Diesel Engine Technology
No new posts Passat Variant 2000: 130 HP Specs & Info Diesel Engine Technology
No new posts Jerking/Hesitation in Passat 3BG 1.9 TDI PD above 2000 RPM Diesel Engine Technology
