Golf 4Motion Turbo: Diagnose & Probleme
efistho
Post03-03-2011, 18:16    Subject: Golf 4Motion Turbo: Diagnose & Probleme Quote
I posted a log under the "Uploads" section.
Could you please take a look at that?
The hoses seem to be okay. The turbocharger was refurbished by a company, and it appears that the problem might be with the N75 valve or a misadjusted VTG (Variable Turbine Geometry).
Best regards, efistho.
Translated on 11-09-2026, 0:04.
Post03-03-2011, 19:12    Subject: Golf 4Motion Turbo: Diagnose & Probleme Quote
Please put the VCDS serial number in your profile and not in the thread! I've removed it; it's irrelevant to everyone except the admin. icon_wink.gif
To the log: Check VTG.
Why was the loader refurbished?
Translated on 11-09-2026, 0:05.
efistho
Post04-03-2011, 9:52    Subject: Golf 4Motion Turbo: Diagnose & Probleme Quote
The car used to have a faulty main control unit.
I've already checked with the workshop again, using the VCDS device.
The owner was looking at the LOG (likely referring to a logbook or similar record) and claims that the VTG (likely referring to a valve or similar mechanism) doesn't have the full range of adjustment and is stuck.
I'll have someone take a look at it again; I can't lift the box right now.
Translated on 11-09-2026, 0:06.
Post04-03-2011, 10:22    Subject: Golf 4Motion Turbo: Diagnose & Probleme Quote
efistho wrote:
The car used to have a really bad main control unit.
A "Murksbox," right?
Translated on 11-09-2026, 0:07.
Deus Violentia
Post04-03-2011, 11:01    Subject: Golf 4Motion Turbo: Diagnose & Probleme Quote
I would also say that Köhlerliesel is sitting under the steering paddles.
BKD GRF
AHF EBF
efistho
Post07-03-2011, 21:49    Subject: Golf 4Motion Turbo: Diagnose & Probleme Quote
The VTG (Variable Turbine Geometry) was stuck because a weasel had chewed on a coolant hose, causing coolant to constantly leak onto the VTG. After only a few months, the turbocharger looked like it had 300,000 km on it.
No new posts Doku Golf 1J, Vibrations and Rumble Noises with 4Motion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 1.9 TDI 4Motion: Starting Problems Diesel Engine Technology
No new posts Disable 4Motion control module in the CAN gateway On-Board Diagnostics (OBD)
No new posts 4Motion: How to Modify All-Wheel Drive Transmission, Chassis, Body & Interior
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
