uhrmeister Guest
14-02-2006, 16:30 Subject: Blinking Relay Noise: Causes & Fixes |
3BG, AVF engine, year 2001, 190,000 km.
The following problem:
More and more often, the turn signal relay rattles wildly (even though the vehicle isn't actually blinking).
That's annoying. Replacing it with a new relay only provided temporary relief.
It's worst when it's cold and damp. If you drive for a long time with the heater on, it gradually stops.
I've already tried spraying wax protectant on the pins of the flasher relay to keep moisture away, but the effect was only temporary.
Does anyone know about this problem and can help?
Bernhard.
Translated on 04-10-2026, 20:04.
pax Profi-Schrauber
2000 Volkswagen Passat Support
15-02-2006, 8:48 Subject: Blinking Relay Noise: Causes & Fixes |
uhrmeister wrote: | | More and more often, the turn signal relay rattles wildly (even though the vehicle doesn't actually blink). | Does this happen when the turn signal lever is activated, or randomly? In the first case, consider the steering column switch.
Bye.
peace
Translated on 04-10-2026, 20:05.
Profile PM Garage |
uhrmeister Guest
15-02-2006, 17:03 Subject: Blinker Relay: Buy Online | Best Prices |
The rattling sound occurs after you've blinked once, but not immediately after.
A slight wobble in the steering column lever cannot cause the rattling sound; instead, it usually starts like this:
Just turn it on sometime.
I've already soldered a flyback diode to the relay coil, though.
Impact.
Translated on 04-10-2026, 20:06.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
15-02-2006, 18:10 Subject: Blinking Relay Noise: Causes & Fixes |
Based on my experience with Audis, it's usually (90% of the time) the relay in the hazard light switch.
If not, the problem is usually resolved by replacing the turn signal lever.
Translated on 04-10-2026, 20:07.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
15-02-2006, 21:01 Subject: Blinking Relay Noise: Causes & Fixes |
The rattling sound often comes from a faulty hazard light switch.
Actually, it's a well-known problem. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
uhrmeister Guest
31-05-2006, 11:28 Subject: Blinking Relay Noise: Causes & Fixes |
Thanks for the information. The problem has been resolved after replacing the steering column switch.
Inside the steering column lever, a conductive strip is located on a flat ribbon cable, which sharply curves around...
It's bent at a corner and eventually breaks off.
Bernhard.
Translated on 04-10-2026, 20:08.
matthiasTDI96 Profi-Schrauber
04-02-2011, 20:32 Subject: Blinking Relay Noise: Causes & Fixes |
Ha, now I'm experiencing that interesting phenomenon too. What exactly is it? Is it the steering column switch, or just the turn signal switch? I'm leaning towards the latter.
Does anyone have any reliable information?
04-02-2011, 20:46 Subject: Blinking Relay Noise: Causes & Fixes |
Is the steering column switch.  MfG. Michael
Translated on 04-10-2026, 20:09.
Profile PM Garage |
Octavia_4x4 Schrauber
04-02-2011, 21:14 Subject: Blinking Relay Noise: Causes & Fixes |
Okay, I understand. Please provide the text you would like me to translate from German to English.
Proof can be found here:
The A3, Octavia, Golf IV, and Passat models share the same steering column switches, which have the same quality issue with the sliding contact.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
TDI-GTI-4-Motion wrote: | This is the steering column switch.  |
Translated on 04-10-2026, 20:10.
Profile PM WWW Garage |
04-02-2011, 21:17 Subject: Blinking Relay Noise: Causes & Fixes |
Octavia_4x4 wrote: | | The A3, Octavia, Golf IV, and Passat have the same steering column switches - with the same quality problem at the friction surface. | Not only there, but I've also experienced this multiple times with the A4 and A6.  MfG. Michael
Profile PM Garage |
04-02-2011, 21:22 Subject: Blinking Relay Noise: Causes & Fixes |
Yes, I know, we even had that issue with our V8. It was more about the fact that the steering column switches are identical, meaning they have the same part number.
"Unfortunately, one of the tires on our bus is now in really bad condition and makes a terrible noise."
Translated on 04-10-2026, 20:11.
05-02-2011, 10:51 Subject: Blinking Relay Noise: Causes & Fixes |
"Thank you!"
07-02-2011, 21:52 Subject: Blinking Relay Noise: Causes & Fixes |
Here's my tip: If the left lever with the GRA (likely referring to a control panel) is defective, you can buy the one from a Skoda Superb. It has a simple hourglass symbol on it, but it's cheaper and compatible.
Translated on 04-10-2026, 20:12.
09-02-2011, 19:03 Subject: Blinking Relay Noise: Causes & Fixes |
Great tip, I'll order it! Thanks.
10-03-2011, 19:59 Subject: Blinking Relay Noise: Causes & Fixes |
uhrmeister wrote: | Thank you for the information; after replacing the steering column switch, the problem has been resolved.
Bernhard |
"Not entirely correct; the conductor track is for the cruise control buttons... the turn signal uses solid copper contact strips, as you can see in the link above and in my detailed photos of the disassembled lever."
