Probleme mit BRT im Sharan | Posts 48+
Go to page: Previous  1, 2, 3, 4
Post07-04-2011, 10:00    Subject: Quote
dieselschrauber wrote:
Nach dem Login mit dem in VCDS gezeigten Code sind Druck und Offset des Gebers wieder plausibel, sprich zurückgesetzt.
Okay, I'm ready. Please provide the German text you want me to translate into English.
Translated on 17-07-2026, 4:00.
mhernach
Post07-04-2011, 19:53    Subject: Quote
Okay, so today I replaced the sender and its associated hoses/lines...
To be honest, there was a mess of wires and cables in there, including those related to the climate control system, wiring harnesses, and power steering.
and that with two sturdy metal pipes...
But it's all sorted out now; I have everything back in its place, and everything is working again.
I will be doing another test run tomorrow, and then the new log will be available.
Ich bedanke mich jetzt schon für die Zahlreichen Tipps Tricks und erklährungen. icon_cool.gif
I will also be performing a forced regeneration tomorrow.
I will keep an eye on the ash issue and may flush the DPF if necessary. icon_biggrin.gif
 hier sieht man die 2 Leitungen, Blau und Gelb...
 File size:  90.49 KB
 Viewed:  1473 times
 Da runter soll ich dann mit der Aluleitung Ohh Gott
 File size:  104.53 KB
 Viewed:  1509 times
Translated on 17-07-2026, 4:01.
mhernach
Post13-04-2011, 17:09    Subject: Quote
Okay, I did it! / I managed to do it! / I succeeded!
3 log files, hopefully these are the right ones...
Thank you for your help.
LOG-01-001-003-067.CSV
 File name:  LOG-01-001-003-067.CSV
 File size:  14.3 KB
 Downloaded:  517 times
LOG-01-001-011-067.CSV
 File name:  LOG-01-001-011-067.CSV
 File size:  12.54 KB
 Downloaded:  404 times
LOG-01-001-003-011.CSV
 File name:  LOG-01-001-003-011.CSV
 File size:  50.67 KB
 Downloaded:  439 times
Translated on 17-07-2026, 4:03.
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Seat for VW Sharan 7N Diesel Engine Technology
No new posts Sharan STG in Passat AFN On-Board Diagnostics (OBD)
No new posts VW Sharan Diagnostic Connector Diesel Engine Technology
No new posts Sharan 7N1 Brake Parts & Accessories Transmission, Chassis, Body & Interior
