Dröhnen vom 1Z bei ca. 1500 UpM unter Volllast normal? | Posts 16+
Go to page: Previous  1, 2
Post14-07-2003, 13:25    Subject: Quote
I have a G3 Var 1Z from December 1995.
The noise level was really bothering me, and the flexible pipe had a lot of play, so I had it replaced last time with an inspection. Since the catalytic converter was welded to the old pipe, they also installed a new catalytic converter... EUR 900 for everything. icon_cry.gif
The buzzing sound is still there, but only the clacking noise when starting and stopping has disappeared.
Perhaps my engine mounts are still faulty, or maybe it's the bearings of the engine carrier itself.
http://people.freenet.de/golf-schrauber/motortraeger.jpg
Furthermore, I diligently used a lot of bitumen – but with only moderate success:
http://people.freenet.de/golf-schrauber/rueckbank.jpg
http://people.freenet.de/golf-schrauber/RR_leer.jpg
Constructively, the 1Z exhaust system is quite restrictive: Between the turbo and the MSD (under the rear bench), there are no mounting points, so almost 150 cm and certainly several kilograms of free-floating icon_evil.gif.
Somewhere, that "Dorehnen" must have originated from.
Translated on 17-07-2026, 11:13.
No new posts Doku 4-cylinder. TDI Clattering/Rumbling, Power Loss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Acoustic Noise Analysis: Identifying and Locating Sources... General Tips
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vibration/Humming Noise 1500-1900 RPM Diesel Engine Technology
No new posts 1.9 TDI AWX Engine Noises Under Load Diesel Engine Technology
No new posts No performance at speeds below 1500 RPM Diesel Engine Technology
No new posts Soot Levels Under 5%: Is This Normal? Diesel Engine Technology
