Climate control, Passat, 1997, temperature reversed
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
chli1976
Karma: +185 / -0   Thank you, like it!
Post17-05-2011, 21:35    Subject: Climate control, Passat, 1997, temperature reversed Quote
I have a Passat, model year 1997, where the air conditioning system is not working.
I'm getting 2 bar of pressure on the low-pressure side and only 2 bar on the high-pressure side when the system is idling.
I thought it might be due to a lack of refrigerant. I extracted 450 grams, and filled it with 1150 grams.
Now I have a static pressure of 5 bar. When I let the engine idle, the low-pressure side drops to 2 bar, which is normal, but the high-pressure side also drops to 2 bar.
I have now measured the temperatures.
On the suction side, after the expansion valve, I'm also measuring 26°C at the compressor.
On the high-pressure side, I have 28°C after the compressor, but only 2°C at the dryer! And before and after the expansion valve, the temperature is between 6°C and 11°C, which is exactly the opposite of what it should be.
Tap the expansion valve.
Could it be that if the expansion valve is open too much, I'm not getting enough pressure on the high-pressure side, and that's why the dryer is getting so cold?
What else I've noticed. After the engine is stopped, the pressures increase more slowly than usual until they reach the static pressure level again.
VCDS
Post18-06-2011, 17:56    Subject: Climate control, Passat, 1997, temperature reversed Quote
The problem is with the saturated/defective dryer!
chli1976
Post18-06-2011, 21:30    Subject: Climate control, Passat, 1997, temperature reversed Quote
Have you experienced this problem before, or are you just suspecting it?
But it sounds logical. If the dryer is a bottleneck, then the refrigerant expands here.
VCDS
Post18-06-2011, 22:55    Subject: Climate control, Passat, 1997, temperature reversed Quote
I once had a similar problem, just as you described. The bottleneck is the dryer, and after that bottleneck, the airflow expands. The dryer isn't expensive, and neither is the expansion valve.
chli1976
Post18-06-2011, 23:08    Subject: Climate control, Passat, 1997, temperature reversed Quote
Thank you.
VCDS
Post18-06-2011, 23:15    Subject: Climate control, Passat, 1997, temperature reversed Quote
If the dryer is working properly, the pipe that goes in will be warm/hot, and the pipe that goes out will be cold.
You can check it if you like.
If there is no significant temperature difference between the two lines, then it's not due to that. icon_wink.gif
chli1976
Post18-06-2011, 23:51    Subject: Climate control, Passat, 1997, temperature reversed Quote
OK, I will check.
VCDS
No new posts Conversion from g/s to mg/H (mg/Hub) and vice versa General Tips
No new posts P0634 - Internal PCM/ECM/TCM temperature too high General Tips
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Temperature 1.6 liter TD with intercooler, 80hp, VW Passa... Diesel Engine Technology
No new posts Air conditioning not working - Passat, 1997 Transmission, Chassis, Body & Interior
No new posts ATF Temperatur On-Board Diagnostics (OBD)
No new posts TDI A4: Max. Particle Filter Temp. 170 PS Diesel Engine Technology
