chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
08-09-2011, 12:19 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Hello!
I'm experiencing a significant loss of power in my Audi A6 4B 2.5 TDI.
The mass airflow sensor (MAF) values are very low, as is the boost pressure. The MAF sensor has already been replaced, but there has been no change.
Lt. dem  liegt die vermutung bei einem def. Cat.
Is there a way to use VCDS to check if the catalytic converter is actually defective?
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:16.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
08-09-2011, 13:17 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Looking inside the KAT (catalytic converter) is the only thing that helps. Are you sure the turbocharger is being controlled correctly?
Keyword: Vacuum sleeving.
Translated on 16-10-2026, 11:17.
Profile PM WWW Garage |
chriskross Blaumann
08-09-2011, 13:44 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Yes, the vacuum pressure is correct, and the VTG (Variable Turbine Geometry) adjustment is working properly.
There's no rattling sound when you tap the KAT either.
NW looks good too.
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:18.
mullemaus Guest
08-09-2011, 14:25 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Are you sure the pressure sensor itself is intact?  Test it during startup to see if it actually engages.  And when you stop, check if it retracts. }
chriskross Blaumann
08-09-2011, 14:37 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
I tested the pressure vessel with a vacuum pump, and there was no pressure loss.
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:19.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
08-09-2011, 14:45 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Does it also work under vacuum?
"Previously, the plastic hoses located above the splash guard, where the hose leading to the brake booster connects, were leaking."
Just try taking it apart and, if you're a smoker, try blowing a little smoke into it and see what happens.
Profile PM Garage |
chriskross Blaumann
09-09-2011, 8:25 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
I replaced the catalytic converter, and now it's running wonderfully again.
I'm going to cut off the catalytic converter and post a picture if anyone is interested.
Best,
Chris
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:20.
jarobaldu Profi-Schrauber
09-09-2011, 8:57 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Yes, please.
A.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
chriskross Blaumann
09-09-2011, 14:41 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
Attached are the photos  .
| Description: |
| File size: |
80.83 KB |
| Viewed: |
9250 times |
| Description: |
| File size: |
114.18 KB |
| Viewed: |
11871 times |
| Description: |
| File size: |
94.42 KB |
| Viewed: |
9618 times |
A6 AFB
A6 BRE DPF
09-09-2011, 18:37 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
It just looks really messy.
Air mass okay, and no leaks in the charge air system? Is the software original?
chriskross Blaumann
09-09-2011, 20:38 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
The vehicle had previously been tested on a dynamometer, and it was only producing 90 horsepower at the wheels.
AFB 150 hp.
According to the customer, something was modified on the software, resulting in approximately 180 horsepower, similar to the AKE.
The vehicle has been running perfectly since the catalytic converter was replaced and has full power.
Best, Chris.
A6 AFB
A6 BRE DPF
Translated on 16-10-2026, 11:21.
09-09-2011, 20:53 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
And does it leave a trail of smoke like a steam locomotive when running at full speed?
To be honest, I wouldn't be surprised if this is a consequence of a failed attempt at "boundary limitation through air mass manipulation"...
Translated on 16-10-2026, 11:22.
09-09-2011, 21:46 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
I'd like to try troubleshooting here as well.
It's only a matter of time before the "new" one looks like that again.
Is it just loose soot that can be removed by scraping, or is it a really hardened mass?
Translated on 16-10-2026, 11:23.
Profile PM Garage |
chriskross Blaumann
10-09-2011, 9:45 Subject: A6 2.5 TDI No Power: Common Problems & Fixes |
The soot can be scraped off; it's not baked on!
I no longer have the car, I have no idea who did the tuning, and I couldn't detect any excessive smoke during the test drive, it seemed perfectly normal.
Best,
Chris
A6 AFB
A6 BRE DPF
