Sägen im Leerlauf und flackerndes Licht bei Allroad 2.5 TDI | Posts 16+
Go to page: Previous  1, 2
Steffen W
Karma: +104 / -0   Thank you, like it!
Post18-10-2011, 19:37    Subject: Quote
I now have a Bosch 140A alternator installed, and it's working perfectly. By the way, I took pictures of both alternators from the back for those interested, including anyone who wants to see them during their lunch break. The Bosch regulator that's installed here has the connector in the same position on the edge of the housing, but the difference is clearly visible.
I submitted the Valeo Lima headlights for warranty today. Please keep your fingers crossed that it goes through successfully.
 Valeo Lichtmaschine
 File size:  39.66 KB
 Viewed:  3467 times
 Bosch Lichtmaschine
 File size:  37.23 KB
 Viewed:  6144 times
Passat Variant BGW 2005
Translated on 10-08-2026, 7:15.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post19-10-2011, 14:27    Subject: Quote
I think you won't have any more problems with the Bosch product.
Do you happen to have a part number so I can order a Bosch replacement in advance?
Translated on 10-08-2026, 7:16.
Steffen W
Post19-10-2011, 20:18    Subject: Quote
Sure. See the image. It's a 140A Lima alternator from a Passat BGW, with a free-running pulley that has 5 grooves.
 Bosch 140A Lima
 File size:  17.98 KB
 Viewed:  2823 times
Translated on 10-08-2026, 7:17.
Tagessuppe
Post20-10-2011, 9:54    Subject: Quote
Steffen W
Post20-10-2011, 16:52    Subject: Quote
Yes, definitely.
Why are you surprised by that? The originally installed 120A Valeo starter also had one. The defective Remy starter did as well.
Translated on 10-08-2026, 7:18.
Tagessuppe
Post20-10-2011, 17:44    Subject: Quote
Well, I'm surprised because the parts list for the V6 Lima doesn't include any free-running hubs.
I've been looking into this myself because I suspect that the missing free-running clutch, combined with the Tiptronic transmission, might be causing the LIMAs to fail.
That would be easy to clarify if you had a photo of the other side of the Bosch device.
Steffen W
Post20-10-2011, 20:04    Subject: Quote
Please provide the text you would like me to translate from German to English, keeping all [/img] exactly as they are. I will only provide the translation.
 File size:  32.17 KB
 Viewed:  2677 times
Translated on 10-08-2026, 7:19.
Tagessuppe
Post21-10-2011, 10:56    Subject: Quote
Yes, it definitely looks like a free-range system.
Tagessuppe
Post21-10-2011, 11:01    Subject: Quote
Okay, now I understand. It's for the 4-cylinder TDI engine.
I was talking about the one in the V6.
Translated on 10-08-2026, 7:20.
Steffen W
Post29-10-2011, 8:56    Subject: Quote
She is recognized.
 File size:  72.17 KB
 Viewed:  946 times
Tagessuppe
Post29-10-2011, 20:18    Subject: Quote
Great!
Good news from my end as well. I finally got around to replacing the regulator today.
Luckily, my original Valeor controller fits.
It had a replica controller with a strangely shaped heatsink.
By the way, the old regulator was not properly screwed onto the two relevant screws that it should have been connected to in order to conduct electricity.
Whether screwing it in would have fixed the problem didn't matter to me; I preferred to have an original regulator working inside.
The voltage is like the old Lima generator, at 14V, and it stays there.
No sawing or flickering!
Replacing the regulator was quite straightforward, and thanks to the newly installed carbon brush retainer, there were no problems when installing it either.
Translated on 10-08-2026, 7:21.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reminder Tone: Light & Sound Transmission, Chassis, Body & Interior
No new posts Electrical Lighting: Solutions & Ideas Transmission, Chassis, Body & Interior
No new posts Summer Light: Capturing the Perfect Glow Transmission, Chassis, Body & Interior
No new posts Tiguan AD1 LED Light On-Board Diagnostics (OBD)
