Peugeot 206 - ABS "ueberbremst" | Posts 16+
Go to page: Previous  1, 2
Karma: +1100 / -0   Thank you, like it!
Post11-11-2011, 6:28    Subject: Quote
Wegen der vorgestern etwas reparaturbeduerftigen Kupplungsmechanik icon_rolleyes.gif hatte ich zwischenzeitlich nicht die Moeglichkeit, mich weiter mit der Problematik zu befassen. On the list:
- Clean the wheels, wheel sensors, and toothed rings (or whatever they're called). Open, inspect, and clean any existing connectors, then reassemble them with pole grease.
I won't be able to log the speed signals until next week. That's when I've arranged access to the OEM tester. Since the error is reproducible, I want to show it to the expert. However, he insisted that if a wheel sensor is producing nonsensical readings, an error code should be stored.
Translated on 16-08-2026, 22:23.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Peugeot 406: "ECU Not Found" Error - Fix On-Board Diagnostics (OBD)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Driving Too Dumb? A Brave New World Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
