Winterreifen am Polo 9N :-( | Posts 48+
Go to page: Previous  1, 2, 3, 4
Post08-10-2011, 10:41    Subject: Quote
jörg schmidt wrote:
Honestly, I can't understand your problems.
I also live in a low mountain range area at an altitude of over 400 meters, and we have...
more snow than anywhere else in the surrounding area.
My motto: Install brand new tires. I don't think the tires in this segment will differ significantly from each other.
When I switched from Fulda to Pirelli, I noticeably, meaning significantly more grip
, in the wet, and also on snow.
Hmm, was that still a significant difference? Or if so, was it only because of the new, full tread depth?
I've been using Pirelli Snowsport or Snowcontrol tires, size 195/55-15, on my Ibiza 6L ASZ for several years. Before that, I had Fulda tires on it.
Ah, so it's almost directly comparable to our problem child, the 9N, on which we've only used branded winter tires so far.
What tire pressure do you use for your WR?
Translated on 28-10-2026, 19:22.
Post08-10-2011, 10:56    Subject: Quote
Has the Polo ever been measured?
If it develops a life of its own on uneven ground, it could also be that the toe-in is set too low. I say this because my Golf was also catastrophically misaligned from the factory. VW can't even manage to get the headlight alignment right from the factory, so you can't expect anything better for the axle geometry icon_rolleyes.gif.
Translated on 28-10-2026, 19:24.
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post08-10-2011, 10:57    Subject: Quote
Hi Ulf,
So far, I've always had a pressure of 2.6 bar all around.
Jörg
jörg schmidt
Post08-10-2011, 11:08    Subject: Quote
Oh, I see.
I still owe you an answer.
The Fuldas generally lasted significantly longer than the Pirellis.
Therefore, the rubber compound would also have had to be harder, and the grip would have been lower.
One morning, while driving with the Fulda tires around a curve, I lost control due to a wet road surface and uneven road conditions. I immediately contacted my tire dealer and had them replaced. However, the tread depth wasn't a factor in that situation. The tread depth mainly becomes noticeable when there's water on the road surface.
Jörg
Translated on 28-10-2026, 19:25.
Post08-10-2011, 11:31    Subject: Quote
If it develops a life of its own on uneven ground, it could also be that the toe-in is not set correctly. I say this because my Golf was also catastrophically misaligned from the factory. VW can't even manage to get the headlight alignment right from the factory, so nothing better can be expected for the axle geometry icon_rolleyes.gif.
Answer for Polo and Ibiza: Maybe icon_cool.gif.
They haven't both been on stage yet, and as a measure of the track's condition, I'd rather look at the tire wear pattern, which so far has been largely unremarkable.
To compensate for the slight tendency towards increased wear on the inner suspension components, I adjusted the camber angle on both wheels a few months ago, increasing it slightly (approximately 45 degrees per tie rod).
If that helps in any way, they should be better on track during the upcoming winter.
@Jörg Schmidt: We generally run similar pressures, but the rear tires have about 0.2 bar less pressure than the front tires.
Translated on 28-10-2026, 19:27.
jörg schmidt
Post08-10-2011, 12:03    Subject: Quote
@Ulf
With more toe-out, the car reacts slightly more sensitively to steering inputs.
I'm not sure, but maybe that will only make your problem worse.
Just this year, I've had the alignment checked twice. With the roads these days... icon_confused.gif
Staying in the correct lane is essential for proper driving.
I once owned a Passat station wagon. When I bought it, I was almost afraid to drive above 80 km/h on a dry road.
When the alignment was properly adjusted, the box felt very stable on the road.
Jörg
Translated on 28-10-2026, 19:29.
Post08-10-2011, 12:14    Subject: Quote
ulf wrote:
Neither of them had been on the stage before, and as a measure of the track, I would rather consider the tire wear pattern, which has so far been largely unremarkable.
"On mine, the wear was still within acceptable limits after over 30,000 km, but it still had a full degree (!) too little negative camber on the right rear."
To compensate for the slight tendency towards increased wear on the inner edges of the control arms, I adjusted the camber slightly more on both wheels a few months ago (approximately 45 degrees of rotation per tie rod).
If that helps in any way, they should stay on track better during the upcoming winter?
Generally speaking, I would expect that to be the case, assuming everything else is consistent. More toe-in results in better on-center stability, but also increased wear.
Translated on 28-10-2026, 19:31.
Post08-10-2011, 12:37    Subject: Quote
jörg schmidt wrote:
@Ulf
I'm not sure, but maybe that will worsen your problem.
It will be shown... but I think not, because so far, the tendency to slide on mud/ice has had to be countered with quite strong steering adjustments - and without creating a tendency to lift up.
Roger wrote:
In my case, the wear was unremarkable even after over 30,000 km, but it still had a full degree (!) too little camber on the rear right side.
. . . which, as far as I know, cannot be adjusted on the 9N platform?
Translated on 28-10-2026, 19:33.
Post08-10-2011, 12:50    Subject: Quote
Okay, that only works with a rear single-sided swingarm. I just wanted to point out that there can already be factory-installed defects.
Translated on 28-10-2026, 19:34.
Post17-02-2012, 10:25    Subject: Quote
@Ulf:
What tires did you end up getting?
And how satisfied are you with it?
Post17-02-2012, 11:44    Subject: Quote
Roger wrote:
@Ulf:
Hello Roger,
those who:
ulf wrote:
Earlier (October 7, 2011), I ordered a set of Dunlop WinterSport 3D tires in size 195/55 R 15 from the local tire shop, hoping that, in addition to Roger's description, the many good test reviews would also be (at least somewhat) accurate.
So far, I haven't heard any complaints. But until now, this winter hasn't presented us with road conditions comparable to those in the past, when the problems with the other WRs became much more apparent.
Translated on 28-10-2026, 19:35.
Post17-02-2012, 12:21    Subject: Quote
THX.
Translated on 28-10-2026, 19:36.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Winter Tires in Summer: Should You? Transmission, Chassis, Body & Interior
No new posts Continental Winter Tires Transmission, Chassis, Body & Interior
No new posts Winter Tires: Maximize Performance & Safety Transmission, Chassis, Body & Interior
No new posts Winterreifen: Michelin Alpin A4 or Dunlop WinterSport 4D? Transmission, Chassis, Body & Interior
