I would either disconnect the old cable or, as I wrote at 10:42, repair it:
guste100 wrote: |
My tip for cable breaks: The distribution, where a cable is split into three pins, is likely to be the problem. A common source of errors. EDIT: So, near the amplifier, free the cable bundle from its outer casing and look for the splice.
The error in the BnSTG system occurred on March 6th and is likely due to the removal of a safety box (SB), which resulted in a loss of power supply to the BnSTG.
