Blackfrosch wrote: |
| LLT is measured in the LLK |
. This is correct for the SMICs of the G4 and 9N platforms, as the sensor is located in the outlet airbox on the hotter rear side of the cooling net. However, my diagram comes from the BUK, whose LD-LLT sensor is located approximately ½ m behind the FMIC, and by that point, the initially temperature-stratified charge air should have already mixed into a largely homogeneous temperature distribution due to several pipe bends.
Quote: |
| Looking at the entire LD system, the charge air is not as hot as the LLT sensor indicates. |
In the BUK, the maximum LLT in 3rd gear is approximately 5,000 meters above sea level (üAT), and in 4th gear, it's around 12,000 meters üAT (the heat sink effect of the FMIC significantly delays the LLT increase; at maximum speed, the LLT stabilizes at around 20,000 meters üAT). Where should the lukewarm charge air, after the measurement point, lose a significant amount of temperature as it travels through the engine bay, which is already warm, and into the hot engine block?
Quote: |
The LMM measures the cold intake air.
That would be my only explanation that spontaneously comes to mind. |
Nevertheless, the LMM (Lambda Measuring Module) can only measure the mass flow, which is limited by the temperature profile after the compressor and the displacement (x charge pressure). The intake air, as a base temperature, should not significantly affect the normalized intake air mass (e.g., normalized to 50°C).
However, the fresh air drawn in is heated before the intake valves close, which, due to the resulting pressure loss, leads to a stagnation effect of the mass flow. And this mass flow stagnation effect increases with the amount of heat added to the intake air within the engine block. Let's assume, for simplicity, that the wall temperature of the intake passages and cylinders is constantly at 90°C, the same as the coolant temperature; then, the aforementioned stagnation effect would be...
a) At 90°C, the LLT (Low-Level Trigger) is not present (because the LLT is not changed until the inlet valves close).
b) the lower the LLT is below 90°C, the stronger the effect.
This explanation, in my opinion, logically leads towards the observed phenomenon that, with a decreasing Lower Limit Temperature (LLT), not much more mass enters the cylinders than one would expect based solely on the LLT value... and it seems to me that the aforementioned correction with the exponent of 0.6 is probably just a coincidence for my BUK logs }.
