Quietschen bzw. Surren der Lenkung | Posts 16+
Go to page: Previous  1, 2
Warmduscher
Post26-07-2012, 10:16    Subject: Quote
Does the car have Servotronic, and will the steering become easier or harder, similar to a humming/whining/squealing sound?
Is there any known background information? While the fact that the fluid level was at its minimum isn't a major issue, it usually indicates some underlying cause.
Translated on 28-08-2026, 18:29.
servusssss
Post26-07-2012, 13:51    Subject: Quote
Hello everyone,
So far, I have replaced the following parts:
- Free running
- Tension roller
- Belt
When I bought the car, the fluid level was at the minimum mark, and since then it has dropped by approximately 1 millimeter.
It's proving difficult to record the noise, as it's very faint and only occurs when steering. However, I will try.
It doesn't matter whether the air conditioning is on or off.
It is most noticeable when reversing into a parking space.
The steering always feels the same, either light or heavy, except when steering while stationary (which I try to avoid), in which case it feels a bit stiffer at the beginning.
I'm not entirely sure whether the car has Servotronik or not icon_redface.gif.
It's an S-Line model, so I would guess it has Servotronic.
SG.
Translated on 28-08-2026, 18:31.
Post26-07-2012, 15:40    Subject: Quote
I've now replaced the tensioner and the freewheel.
So far, I haven't heard anything more, but I will post an update here if that changes.
Thank you for your help.
Hello everyone,
Unfortunately, the noise is still present.
Available or still in stock?
And where is the fluid leaking, or did the level only stabilize after filling because there was air in the system? If the level continues to drop and there's no visible leak at first glance, you should check under the dust covers to see if any fluid has accumulated there. If so, a new steering rack will likely be needed soon.
Translated on 28-08-2026, 18:33.
servusssss
Post26-07-2012, 19:24    Subject: Quote
Yes, unfortunately, it's back again.
I'm starting to feel like it's louder when the box is warm.
The steering rack boots are dry.
The oil level doesn't change beyond the specified 1mm, so it has stabilized.
Since this issue only occurs when steering, with or without the accelerator pedal engaged, I'm starting to suspect it's the pump.
SG.
Translated on 28-08-2026, 18:34.
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch pedal squeak Diesel Engine Technology
No new posts Clutch Squeal: Causes and Solutions Diesel Engine Technology
No new posts Car Noises: Squeaks and Chirps from the Front Transmission, Chassis, Body & Interior
No new posts V6 TDI Turbo Whine: Vacuum Pump & 1800 RPM Diesel Engine Technology
