Passat 3C or Superb 3T emergency unlock (Solution)
Post21-08-2012, 8:11    Subject: Passat 3C or Superb 3T emergency unlock Quote
If the keyless entry system of a Passat or Superb is malfunctioning, you can still open the vehicle. The lock is located on the driver's side, hidden under the cover behind the door handle.
First, the protective cap needs to be removed.
This is done as follows:
- Remove the emergency key (3C) or unfold it (3T).
- Insert the key into the slot at the bottom of the cap.
- DO NOT lever or rotate!
- simply press upwards.
- The latch releases the cap, and you simultaneously attach it to the key.
After that, the driver's door can be unlocked using the (spare) key.
A potential engine stall will occur, but this will be resolved by inserting the key into the ignition switch.
Passat 3C or Superb 3T emergency unlock (Solution) - 3CNotentriegelung.flv
 Passat 3C oder Superb 3T Notentriegelung
 File size:  765.4 KB
 Viewed:  13300 times
 File size:  68.83 KB
 Viewed:  49895 times
Translated on 19-07-2026, 17:48.
Ratings - Passat 3C or Superb 3T emergency unlock
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat/Superb: Accessing Engine Bay from Interior Transmission, Chassis, Body & Interior
No new posts Passat 3C: Transmission or Dual Mass Flywheel? Diesel Engine Technology
No new posts Passat 3B: V6 TDI/PD Fuel Consumption with 6-Speed Diesel Engine Technology
No new posts Passat AFN: CAN-Bus on MSG - Yes or No? On-Board Diagnostics (OBD)
