30-10-2012, 0:37 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
The 2.0 xPD corks are considered "full" with a weight of 60g and can therefore be used as replacements.
Roughly speaking, at around 200,000 kilometers, you can expect to have to dig deep into your pockets.
What is the limit for the 3.0 TDI ASB/CDYA engine? (The label file doesn't specify this, unlike with the 2.0 engines.)
This question mainly arises when buying a used car, especially if the Diesel Particulate Filter (DPF) needs to be replaced just 2 months after purchase.
Greetings.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 20-07-2026, 4:54.
Profile PM Garage |
michiglaser Blaumann
Joined: 05/03/2007 Posts: 274 Karma: +6 / -0 Location: Lkr. KEH 2007 Audi A4 Avant Premium Support
06-11-2012, 21:15 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
Translating... |
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG) |
Profile PM Garage |
mullemaus Guest
06-11-2012, 23:08 Subject: Re: When is the DPF full on a 3.0 TDI (ASB or CDYA)? |
This question arises especially when buying used cars, for example, if the DPF needs to be replaced 2 months after purchase.
12 months warranty when purchasing commercial property, with the first 6 months without a reversal of the burden of proof. This should therefore not be of interest to the buyer  .
Translated on 20-07-2026, 4:56.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
07-11-2012, 8:00 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
Hmm, isn't the DPF considered a wear and tear part?
Profile PM WWW Garage |
Georg-TDI Guest
07-11-2012, 12:55 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
The DPF is clearly a wear item!
Where I was planning to buy a Passat with 149,000 kilometers on it,
I have inquired with several sources (including friends and the ADAC).
I've now driven 10,000 kilometers.
=> no oil consumption.
=> The ash content remains at 42.
Greetings, Georg.
Translated on 20-07-2026, 4:57.
07-11-2012, 13:00 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
If the DPF is due for replacement soon, you could try to negotiate a lower vehicle price by deducting the cost of replacement and then have it cleaned yourself.
This is how you arrive at a very good hourly rate.
Translated on 20-07-2026, 4:58.
07-11-2012, 14:11 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
Hi.
The Audi A6 was purchased last Saturday – I wasn't there.
Next Saturday, he will be "available," and I'll soon be showing up with "the cable"... then I'll report back.
200ml as "full" - that's a valuable piece of information, thank you.
Translated on 20-07-2026, 4:59.
Profile PM Garage |
Tobi12345 Blaumann
Joined: 03/29/2005 Posts: 151 Karma: +2 / -0 Location: nähe Hamburg
07-11-2012, 15:55 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
"If the ash content is less than or equal to 60 grams or less than or equal to 0.52 liters, the vehicle can be operated for an additional 30,000 kilometers." Quote from ElsaWin.
This weight reduction of 60 grams applies to the 4-cylinder engines, while the 0.52 liter increase in volume refers to the 6-cylinder engines.
"On my tuned A6 3.0 TDI with 127,000 km on the odometer, the ash mass is currently at 0.20. Therefore, based on this rate, the DPF should reach its end of life around 360,000 km." A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 20-07-2026, 5:00.
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
05-12-2012, 19:26 Subject: When is the DPF full on a 3.0 TDI engine (with ASB or CDYA code)? |
dieselschrauber wrote: | | Hmm, isn't the DPF considered a wear part? |
Hi there,
"Flush it out! Mine is due for an additive change every 120,000 km, I've had it done twice, and then flushed it. I didn't even have to remove the catalytic converter; I just tilted the thing upright backwards, used a bucket of water, aimed from a high position, and poured a lot in quickly. It comes out quite a bit. I also tried using a Kärcher pressure washer once, but you have to be careful with the distance, and the flow rate and speed within the catalytic converter aren't as good anymore. A garden hose nozzle works just as well."
Using the Garden method, I achieve the same differential pressure values as new parts or OEM automatic transmission filters, even with the same engine speeds (RPM), mass airflow rates (MAF), and air temperatures (AT).
My second filter was also just an AT filter, and now it's been used in another vehicle with approximately 400,000 km on it since its first service (at the 120,000 km mark, where the service is officially taken over). The exhaust system is spotless, or rather, has rust deposits from the system in the stainless steel end pipes. I flush it out every 60,000 km. You can save yourself the €400 for an AT filter or €800 for a new OEM one.Experiences suggest that filters without additives should be able to maintain their performance; however, I can only provide information for a filter that cleans at an ignition temperature of approximately 500°C. Peugeot 307 (T5)1450kg Speck, RHS, MJ2002, 138g CO2 inkl. Korken im Auspuff und goldene Möhre 2006, MAF+50% mit passender Dieselmasse. nunmehr 370000km
Translated on 20-07-2026, 5:03.
