Intermittent power issue, Alfa 156 2.4 JTD common rail, 100,000 km
andymueller
Post11-08-2003, 9:33    Subject: Intermittent power issue, Alfa 156 2.4 JTD common rail, 100,000 km Quote
Hello everyone,
I have the above. Problem starts around 2000 RPM and continues until the engine shuts down.
No error code stored, according to the garage.
'The following defect loop has been identified:'
1. LMM (already cleaned, but no improvement!)
2. Fuel pressure sensor, rail pressure (electric). (Connections checked)
3. Pressure vessel (operates under pressure) for a VTG loader, Garrett brand (tested with an air pump, and appears to be in good condition).
Here are the following steps I still want to complete:
- Replace pressure vessel? (Is the membrane soft?)
- Check the fuel pressure sensor (suggestion?).
-'Trying a 'diode trick' on the LMM?'
Has anyone else experienced a similar problem, or does anyone have any tips?
You're welcome for the information.
Andy
andymueller
Post25-08-2003, 21:55    Subject: Intermittent power issue, Alfa 156 2.4 JTD common rail, 100,000 km Quote
After modifying the connector to the Bosch mass airflow sensor (MAF) with a diode, the problem was largely resolved.
After that, I installed a new Bosch mass airflow sensor, and now it's perfect. Unfortunately, it was a bit expensive! A Pierburg alternative would be welcome if we knew which one would be compatible.
Andy
diesel.gustav
Post27-08-2003, 20:37    Subject: Intermittent power issue, Alfa 156 2.4 JTD common rail, 100,000 km Quote
Deleted as requested.
andymueller
Post28-08-2003, 0:10    Subject: Intermittent power issue, Alfa 156 2.4 JTD common rail, 100,000 km Quote
Hello Gustav,
Thank you for the information. It would have been possible.
Andy
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. 10 cent tuning for common-rail engines Diesel Engine Technology
No new posts Alfa 159 1.9 JTDM Diesel Engine Technology
No new posts Semi-pro system review on Alfa On-Board Diagnostics (OBD)
No new posts Bild von Einspritzdüsen mit 239.000km !! Diesel Engine Technology
