AGR Potentiometer Check: BLS with DPF.
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Martininii
Karma: +24 / -1   Thank you, like it!
Post07-02-2013, 23:27    Subject: AGR Potentiometer Check: BLS with DPF. Quote
Caddy 2KA, 1.9 TDI, BLS engine, original DPF, 105 hp (0603/AGB).
How can the potentiometer of the EGR valve be tested? This refers to the EGR valve shown in the picture.
Normally, you can test a potentiometer by connecting the middle terminal to one of the outer terminals using a multimeter and checking for a certain resistance value. This works for me as well. However, when I push the potentiometer inwards, the resistance doesn't change.
When it comes to cars, many things are different compared to regular electronics, which can sometimes seem illogical if you're used to how things work in other areas.
Perhaps someone has an EGR valve that they could use for testing. Or, does anyone know how to properly measure this component?
To describe the plug connection of the plastic cover on the EGR valve, as shown in the first picture:
The two top contacts connect directly to motor terminal A and terminal B, respectively, without any resistance. The three bottom contacts are connected to the potentiometer.
 (c)martininii
 File size:  424.88 KB
 Viewed:  5050 times
 (c)martininii
(c)martininii
 File name:  AGR kurz nach Ausbau.jpg
 File size:  254.3 KB
 Downloaded:  1150 times
 (c)martininii
(c)martininii
 File name:  AGR Poti und MotoranschlĂźsse.jpg
 File size:  246.2 KB
 Downloaded:  1258 times
 (c)martininii
(c)martininii
 File name:  AGR Gehäuße.jpg
 File size:  302.46 KB
 Downloaded:  1038 times
 (c)martininii
(c)martininii
 File name:  AGR Ventil.jpg
 File size:  256.77 KB
 Downloaded:  1090 times
 (c)martininii
(c)martininii
 File name:  AGR Sitz.jpg
 File size:  331.41 KB
 Downloaded:  1009 times
 (c)martininii
(c)martininii
 File name:  AGR Eingang.jpg
 File size:  274.29 KB
 Downloaded:  1417 times
 (c)martininii
(c)martininii
 Downloaded:  1068 times
Caddy 3 mit BLS Motor, 105PS, DPF (0603/AGB)
Renault Laguna 2 mit F9Q Motor, 107PS/120PS (3004/158)
Translated on 01-08-2026, 4:21.
Post08-02-2013, 15:02    Subject: AGR Potentiometer Check: BLS with DPF. Quote
Since it doesn't necessarily have to be a potentiometer, for example, inductive measurement is used in BRE motors.
The plastic gears in the actuator are more likely to break, so it's best to disassemble it and take a look.
Translated on 01-08-2026, 4:23.
Martininii
Post08-02-2013, 15:28    Subject: AGR Potentiometer Check: BLS with DPF. Quote
I just took it apart and put it back together, and now I'm a little smarter than before icon_biggrin.gif, and luckily, I didn't break anything.
Unfortunately, I only took one picture, which shows what's inside.
This core is pushed out by two feathers.
Above that, visible from the outside, is another cover, underneath which sits a small piece of electronics that has been encased in this waterproof gel. (Unfortunately, I didn't take a photo.)
If you open the lid first, you might suspect that there's a potentiometer underneath... However, it's likely that the resistance is being measured inductively, as the core is equipped with metal and surrounded by an invisible coil.
I had to re-glue the lid because it wasn't staying on anymore.
 Kein Potentiometer, ein induktiver Drehwinkelsensor
 File size:  282.12 KB
 Viewed:  2992 times
Translated on 01-08-2026, 4:24.
Post08-02-2013, 17:21    Subject: AGR Potentiometer Check: BLS with DPF. Quote
A potentiometer is something else; that's an inductive rotary angle sensor. icon_idea.gif
Translated on 01-08-2026, 4:26.
Martininii
Post08-02-2013, 18:32    Subject: AGR Potentiometer Check: BLS with DPF. Quote
I got this information from a potentiometer supplier in an automotive workshop. It seems that was incorrect information.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post08-02-2013, 20:55    Subject: AGR Potentiometer Check: BLS with DPF. Quote
Hmm, that's linear motion.
reflexsilber met.
Post08-02-2013, 22:22    Subject: AGR Potentiometer Check: BLS with DPF. Quote
How can the potentiometer of the EGR valve be checked? It refers to this EGR valve, as shown in the picture.
The best tool for this is the STG (control unit) -> Connect it -> Turn on the ignition -> Go to the corresponding measurement block, move the sensor, and check the values for plausibility.
Only when something appears to be defective should one consider how to test the "component" before potentially confirming that it is indeed defective. icon_rolleyes.gif
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 01-08-2026, 4:27.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ALWR sensors with (quasi) potentiometer output Electrical Systems, Vehicle Electronics, Multimedia
No new posts Potentiometer, Servo motors, Air conditioning system, Aud... Transmission, Chassis, Body & Interior
No new posts Standby Power Failure: Troubleshooting Potentiometer. On-Board Diagnostics (OBD)
No new posts Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal... Diesel Engine Technology
