dave81
Joined: 11/10/2012 Posts: 13 Karma: +0 / -0 Location: Oberhausen 2005 Audi A3 Premium Support
12-02-2013, 14:02 Subject: Golf 5 R32 Supercharger - Ignition Control, Cylinder 4 |
Hello friends,
We have a Golf 5 R32 with the engine code "BUB" that has been modified with a supercharger by SLS. On the way to work this morning, the check engine light came on. The car was running normally, with full power - all 6 cylinders were working. The car was carefully moved back home - the spark plugs were checked, but they were all securely in place.
Connected the car to VCDS and received the following error:
Address 01: Engine Label file: None
Part number SW: 022 SLS 032 CD. Part number HW: 022 906 032 GP.
Component: MOTRONIC ME7.1.*G SLS1
Revision: --H02--- Serial number: VWZ7Z0G8128678
Encoding: 0000172
Operating number: WSC 01279 785 00200
VCID: A24D2DDB7D658F08978
"1 error found:"
004964 - Ignition control, cylinder 4.
P1364 - 004 - Interruption - Intermittent - Warning light ON.
Readiness: 0010 0001
The error has been fixed, and a test drive has been conducted. Everything is fine - no major issues.
Unfortunately, I couldn't find any information about the error code "004964".
I wanted to wait until the ignition coils were replaced (action: 28E9) and then see what else needs to be done.
Does anyone have any ideas?
The scan is attached.
| Description: |
 Download |
| File name: |
Log-OB GR 32-WVWZZZ1KZ7W272681-71790km.txt |
| File size: |
8.98 KB |
| Downloaded: |
1397 times |
Profile PM Garage |
Joined: 04/12/2002 Posts: 18130 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
12-02-2013, 14:09 Subject: Golf 5 R32 Supercharger - Ignition Control, Cylinder 4 |
Error P1364 - Cylinder 4 Ignition: Interruption.
Possible symptoms:
- Engine fault light ON.
- Misfire
- No spark.
Possible causes:
- Faulty ignition coil.
- Defective fuse(s) (loose connection).
- Faulty wiring or connector between the ignition coil and the engine control unit.
Profile PM WWW Garage |
dave81
12-02-2013, 15:12 Subject: Golf 5 R32 Supercharger - Ignition Control, Cylinder 4 |
Hello Rainer,
Thank you for the quick response. I initially started with the 004964 number, which caused some confusion.
As I said, I will have the dealership perform the action and then check it again.
Thanks and greetings.
David.
Profile PM Garage |
