Xoctron
Joined: 12/17/2012 Posts: 31 Karma: +0 / -0 Location: 77839 Lichtenau
02-01-2013, 19:28 Subject: Multifunction steering wheel (Solved) |
I want to install a MuFuLe system in my Touran.
Does it have to be the steering wheel with 4 buttons, or would the newer one with the "joysticks" also work, like the one installed in the current Touran?
If anyone happens to have one they're willing to part with, please let me know and make me an offer.
Translated on 06-07-2026, 18:25.
Xoctron
06-01-2013, 20:53 Subject: Multifunction steering wheel (Solved) |
I got a different steering column control unit today:
Currently installed is the part with the number 1K0 953 549 BN.
This will be replaced by 1K0 953 549 BS.
According to the ross-tech wiki, this is a Highline model and should therefore support MFL and the already installed GRA.
Now, all that remains is the question of the steering wheel.
Does it have to be a steering wheel with the round buttons, or would the new version with the rectangular buttons also work?
Has anyone installed the new version and can tell me if it works?
Michael
Translated on 06-07-2026, 18:26.
07-01-2013, 10:15 Subject: Multifunction steering wheel (Solved) |
If you already have a steering column control module, you've likely configured the LIN communication for the steering wheel, probably using LIN 1.3.
That makes it clear that it must be an "old" 8-button [device/control panel].
Translated on 06-07-2026, 18:27.
Profile PM Garage |
Xoctron
07-01-2013, 10:22 Subject: Multifunction steering wheel (Solved) |
Thank you. The BS is LIN 1.3. I've learned something new about that. Could I also use the new steering wheel with LIN 1.3/2.0?
Translated on 06-07-2026, 18:28.
07-01-2013, 16:57 Subject: Multifunction steering wheel (Solved) |
Probably.
Profile PM Garage |
Xoctron
07-01-2013, 23:09 Subject: Multifunction steering wheel (Solved) |
If I knew that it would work safely without me needing to purchase a more recent gateway, I would get another steering wheel control unit.
I will now do some research to find out which MFL (Multi-Function Lever) is compatible with my airbag and will stick with the "smaller version."
Slip ring 1K0 959 653 C and GRA lever 953 513 G are installed.
If I can find the correct MFL (Multi-Function Lever) for the airbag, then nothing should stand in the way of the conversion.
Thank you for your help.
I will report.
Translated on 06-07-2026, 18:29.
Xoctron
02-03-2013, 13:18 Subject: Multifunction steering wheel (Solved) |
Yesterday, I installed a multifunction steering wheel from a Golf 6.
So far, everything is working. "Except for the Bluetooth pairing with the UHV."
"Previously, there was no MFL installed. The instructions state that you should press the telephone button twice in quick succession within 5 seconds of turning on the ignition, and then you should hear an audible signal. Unfortunately, that's not happening for me." Do I need to code anything else there?
| Description: |
| Multifunktionslenkrad Golf 6 |
| File size: |
209.41 KB |
| Viewed: |
15971 times |
| Description: |
 Download |
| File name: |
Log-RA-MW2912-WVGZZZ1TZ8W149332-136840km.txt |
| File size: |
7.91 KB |
| Downloaded: |
828 times |
Translated on 06-07-2026, 18:30.
02-03-2013, 13:59 Subject: Multifunction steering wheel (Solved) |
I see an empty charging tray and a...
Code: | Adresse 77: Telefon Labeldatei: DRV\3C0-035-729.lbl
Teilenummer SW: 3C0 035 729 G HW: 3C0 035 729 G
Bauteil: Telefon 7609
Revision: 00012000 Seriennummer: 0000B6A102843
Codierung: 0016021
Betriebsnr.: WSC 01324 785 00200
To the best of my knowledge, that doesn't work on the 729G if there's absolutely nothing inside.
At least one earbud or the pairing adapter.
At least, our...
Code: | Adresse 77: Telefon Labeldatei: RKS\3C0-035-729.lbl
Revision: 00012000 Seriennummer: 0000B6A004801
Codierung: 0016041
Betriebsnr.: WSC 00000 785 00200
Exactly like that.
Was das 1K0-953-549-CH already installed?
Because with LIN 1.3 and 2.0, it's a truly remarkable piece of technology.
Too bad, I had installed a different one back then.
Translated on 06-07-2026, 18:31.
Profile PM Garage |
Xoctron
02-03-2013, 14:09 Subject: Multifunction steering wheel (Solved) |
Okay, then I'll look for some kind of adapter on eBay.
I don't understand why VW can't offer current holders. Actually, the Galaxy S3 is already quite common.
I installed the 1K0-953-549-CH because it's the only one that supports LIN 1.3 and 2.0. If I hadn't managed to get the Golf 6 steering wheel working, I could have reverted to the original steering wheel, which I still have, without having to replace the control unit again.
Translated on 06-07-2026, 18:32.
Xoctron
15-03-2013, 14:48 Subject: Multifunction steering wheel (Solved) |
With the pairing adapter, the telephone button on the MFL  now also works.
Translated on 06-07-2026, 18:33.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
15-03-2013, 15:28 Subject: Multifunction steering wheel (Solved) |
Yes, great, and thank you for the feedback  .
